IE stuck on 08.09.06
MrNightly
Anyone know how to fix this problem?
Every time I open windows it is stuck on 8.9.06 on MSN. Is there something I can do? Kinda annoying, because my wife's computer (Same network) is just fine. I tried resetting my homepage to MSN.com, but it just pulls me back to the same date.
Any ideas what might be the problem?
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Make sure your system date/time hasn't been set and stuck on that date. I had that happen somehow a week ago.........comment comment comment comment. bitchy.
I think that you may have the Groundhog Day Virus....................the only known way to cure it is to sleep with Andie MacDowell.:D
Good LuckHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis Gardner wrote:I think that you may have the Groundhog Day Virus....................the only known way to cure it is to sleep with Andie MacDowell.:D
Good Luck
Dang...
Gotta be careful what I post, the wife is known to snoop around here a time or two :eek: Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Rotel RB-985 5-Channel Amplifier -
That is odd. You might check in IE: Tools/ Internet Options/ on the General tab, Temporary Internet Files--> Settings button. Under the top 'check for newer versions of stored pages' option, is it set to 'automatically'?
