IE stuck on 08.09.06
MrNightly
MrNightly Posts: 3,370
edited April 2024 in Clubhouse Archives
Anyone know how to fix this problem?
Every time I open windows it is stuck on 8.9.06 on MSN. Is there something I can do? Kinda annoying, because my wife's computer (Same network) is just fine. I tried resetting my homepage to MSN.com, but it just pulls me back to the same date.
Any ideas what might be the problem?
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub :D:D:D
Denon 3805
Rotel RB-985 5-Channel Amplifier
  • PolkThug
    PolkThug Posts: 7,532
    edited August 2006
  • PolkThug
    edited August 2006
    Try refresh button? Clear your cache.
  • brettw22
    brettw22 Posts: 7,623
    edited August 2006
    Make sure your system date/time hasn't been set and stuck on that date. I had that happen somehow a week ago.........
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2006
    I think that you may have the Groundhog Day Virus....................the only known way to cure it is to sleep with Andie MacDowell.:D
    Good Luck
  • MrNightly
    edited August 2006
    Good Luck
    Dang... ;) Gotta be careful what I post, the wife is known to snoop around here a time or two :eek:
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • dylan
    dylan Posts: 453
    edited August 2006
    That is odd. You might check in IE: Tools/ Internet Options/ on the General tab, Temporary Internet Files--> Settings button. Under the top 'check for newer versions of stored pages' option, is it set to 'automatically'?
