2 channel tuner/preamp suggestions
Sax
Sax Posts: 70
edited August 2006 in Electronics
I'm currently using a piece of shite insignia 2-channel amp as my tuner/preamp to an adcom GFA-545II feeding my RTA's. This thing sounds like a piece of #(#%.
I'm looking around, not sure where I should better spend my money. I need a 2-channel preamp/selector. Some ideas I'm batting around are as follows:
Adcom GFP 450/555/560 something like that
ROTEL RTC-850 or something
I'm really not sure... I figure an adcom will probably go with my adcom pretty good... I'm shooting for a $<=500 ebay range.
Monitor 5b
RTA 11T
Rega Planar 2 (1970's)
Adcom GFA-545II
Post edited by Sax on
  • ESavinon
    ESavinon Posts: 3,067
    edited August 2006
    luxman tp117.
    Excellent tuner/preamp for around $200 on ebay.
    soundstream c1 for around $200 on ebay.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • sucks2beme
    sucks2beme Posts: 5,682
    edited August 2006
    My Nad 917 has a much better tuner than my Rotel 940ax.
  • Sax
    Sax Posts: 70
    edited August 2006
    hmm.. .I'm not so much interested in the tuner ability as I'm needing mainly a preamp for my cd / phono / computer inputs. Radio stations around here moderately suck anyhow... so I'm really just looking for something that sounds the best overall
    Monitor 5b
    RTA 11T
    Adcom GFA-545II
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2006
    Marantz now makes an AM/FM/XM tuner...very cool.
  • sucks2beme
    edited August 2006
    The Rotels are known to have less problems than some of the Adcom pre's.
    There is a Rotel RSP980 pre on EBAY item 320017609758.
  • Sax
    Sax Posts: 70
    edited August 2006
    How about carver preamps, does anyone have any luck with them? For example a Carver C-1?
    edit: even a CT-7 or something?
    Monitor 5b
    RTA 11T
    Adcom GFA-545II
  • univera
    univera Posts: 848
    edited August 2006
    Sax, I have an NAD 1155 preamp that is in pristine condition that I am currently not using. It was the top of the line preamp from NAD at the time and is known to be very quiet. It doesn't have a tuner, but is suppossed to have an excellent phono stage. I have not actually used it, it was a piece that I picked up at one time with other pieces since the price was right. Perhaps someone has some personal knowledge/use. I read up on it and it seems to be well regarded. You would still need a seperate tuner. Here's a recent Ebay listing that gives some info. http://cgi.ebay.com/NAD-1155-Stereo-Preamplifier-Great-Condition-Preamp_W0QQitemZ260018011315QQihZ016QQcategoryZ14974QQssPageNameZWDVWQQrdZ1QQcmdZViewItem This is a link to a similar model on the NAD website, but they don't list the 1155 in the archives.
    http://207.228.230.231/info/NAD_1130.pdf
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
  • Sax
    Sax Posts: 70
    edited August 2006
    univera... how much would you want for it? I may take you up on that.
    Monitor 5b
    RTA 11T
    Adcom GFA-545II
