Placement Of Other Speakers Near Sda/srs
univera
univera Posts: 848
edited August 2006 in Vintage Speakers
I am trying to place a pair of Def Tech BP 2000's very close to the SDA/SRS as I need my room to be all-in-one for HT/stereo. The DT's are about 3/4 the height of the SDA's. I know that one needs to allow space away from side walls, but I didn't know if having a speaker right next to the SDA's would affect the sound/be the same principle. If I had to choose one, would placing the towers on the inside or outside of the SDA's be most preferable? Are both scenarios going to degrade the performance?
UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team
Post edited by univera on
    F1nut Posts: 51,756
    edited August 2006
    Only one way to find out, try it.
  • univera
    univera Posts: 848
    edited August 2006
    Yes, thanks, I was just trying to save time since moving them around is a pain, but I am preaching to the choir. I just didn't know if it there were any obvious things such as interfering with the SDA effect.
    UNIVERA
    2 Channel:
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    F1nut Posts: 51,756
    edited August 2006
    There's too many variables. One absolute, keep them on the same plane.
  • motorstereo
    motorstereo Posts: 2,331
    edited August 2006
    I have a pair of sansui sp3500's sitting atop my polk sda 2.3's powered by a tube amp. My sda's are powered with an adcom gfa 555. I have the sui's running at a lower volume than the 2.3's and this set up sounds incredible. Kinda imposing looking having speakers almost reach the ceiling but you can't argue with the sound. I actually didn't think this combination would work but it doesn't take away from the sda effect at all.
    F1nut Posts: 51,756
    edited August 2006
    Someone has been taking lessons from Sid.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2006
    It's not rocket science....add another speaker, any speaker, on top on another...and you increase the soundfield. If it sounds good, you should start working as a greeter at Walmart.
  • motorstereo
    edited August 2006
    How did you know that's what I do for work? Hey sometimes stacking speakers doesn't work at all as I'm sure you must've tried a few combos yourself that didn't work. I know I have. This one sounds silly I know and I didn't expect to have the sui's on top of the sda's permanently but I'm afraid they are. I'm not the only one that thinks that it's the cat's pajamas either. All my walmart greeter friends are in awe. Give stacking on some sda's a shot. What you got to lose?
  • dorokusai
    edited August 2006
    :D Hey man, I can't argue with what someone else hears, so I say rock on.
