cable inerds
jdannyj
jdannyj Posts: 26
When cutting my center channel cable to connect banana plugs, i noticed a thin plastic tube that the speaker wire is wound around. do i need to keep this piece with the rest of the cable, or should i seperate it??
Post edited by jdannyj on
    F1nut Posts: 51,786
    edited August 2006
    What kind of wire is this, coax?
  • jdannyj
    jdannyj Posts: 26
    edited August 2006
    it's a monster z2r reference center channel cable. I've noticed this plastic tube in other speaker cable as well, i just don't know if it needs to stay wound up with the rest of the wire?? since the rest of the wire is already wound around it, i guess it should stay that way...
    F1nut Posts: 51,786
    edited August 2006
    Hmmmm...interesting is about all I can say. Maybe someone else will have an answer for you.
  • Sax
    Sax Posts: 70
    edited August 2006
    the plastic tube it is wrapped around is likely a dialectric. has to do with helping to eliminate noise interference.
    When you are stripping the wire though to make your connections that should be fine to trim out of your way for the short section that you are stripping.
    Monitor 5b
    RTA 11T
    Rega Planar 2 (1970's)
    Adcom GFA-545II
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited August 2006
    I was curious about the gauge size of their wires, so I contacted Monster service about 4 months ago. In a "between you and me" moment with the gentlemen on the other line, he stated that the wire in question was only 18 gauge. At first, I couldn't believe it as the wire looked to be at least 14 gauge.
    IMO the "tube" is a way of inflating the perceived gauge size. Take it out of the equation, and you'll see how few conductors you're actually rolling with. Please also refer to the fact that Monster does not divulge the gauge size of their lower end wire.
