Point of Woofers in towers?
KrazyMofo24
KrazyMofo24 Posts: 1,210
edited August 2006 in Speakers
I was wondering what benefits they provide if your using a sub. For example the Rti-10's. Are they strictly if you want to listen them 2-channel without a sub?
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
Post edited by KrazyMofo24 on
  • PolkThug
    PolkThug Posts: 7,532
    edited August 2006
    They fill in the frequencies between the lowest tweeter tone and the highest sub tone.
    VR3 Posts: 29,444
    edited August 2006
    While the 545 is a great amp. IMO its not enough to really get two 8" woofers going...
    300 watts is about the min, IMO.
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2006
    Back in the "olden days" when 2-channel ruled, and a SUB was a sandwich, real speakers had woofers.
    VR3 Posts: 29,444
    edited August 2006
    4 - 8" woofers can move alot of air...
    But it takes a real set of woofers and a real amp to do it.
    The RTi line isnt exactly a powerhouse series by any means. It does what it does and does it within reason.
    F1nut Posts: 51,795
    edited August 2006
    And they still do!!!
  • Toxis
    Toxis Posts: 5,116
    edited August 2006
    Well... because movies and music require midbass. That way when a gunshot goes off or drums are a-rockin', you feel the punch from it. Typically a lot of those sounds are not sub frequencies. You want a full sound so you get a full speaker. Done!
  • josh_parsons626
    josh_parsons626 Posts: 219
    edited August 2006
    Let's take the LSi15 for example. Is that why it has the 8" sub in it, to provide a more fuller sound?
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
  • KrazyMofo24
    edited August 2006
    After watching Munich with the Lsi7's/sub I was hoping the sub was going to give that effect like the 10's did. The sub helped a lot, but didn't have the thump when bomb's and shots were fired. So I'm going back to the 10's for HT. Thanks for the info
    Setup:
  • TroyD
    TroyD Posts: 13,124
    edited August 2006
    There is NO substitute for radiating surface area and a real man's amp.
    Also, if you have a comptently designed amp and you aren't trying to drive either a pair of original Carver Amazings or Apogee Scintilla's the belief that you need hundreds of watts of power is largely not true.
    Anyone who doubts this, come listen to my AR9's and my 75wpc tube amp.
    BDT
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2006
    BDT
    But you're talking about a Tube amp vs. a SS amp, it's not apple to apple too me. :cool:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • TroyD
    TroyD Posts: 13,124
    edited August 2006
    Maybe, but the theory is still the same. I've heard big SDA's powered to earsplitting level, very competently by a little NAD 20wpc integrated or 50-60wpc rotel.
    BDT
  • Sami
    Sami Posts: 4,634
    edited August 2006
    Sell the 10's and get a better sub. I have 7's with SVS PCU and there is no problem for getting it sound great for both HT and 2.1 channel. I also have a pair of 15's but I haven't yet tried them in my HT setup, it might be better but there is nothing wrong with the 7's with a decent sub.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited August 2006
    Watts is Watts, only difference is how they clip.
    BDT, I know 40W wasn't enough for the mags, they should be added to the "abuse amps" section. but I do agree whole heartedly on the point. The SDA1-B's that I had would be deafening at about 4W sustained and 20W transients (based off of carver analog meters)
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • TroyD
    TroyD Posts: 13,124
    edited August 2006
    True enough re the Maggies......
    BDT
  • jdhdiggs
    edited August 2006
    Now if we can just break people out of the biamping kick and get them to buy Man's amps instead...
  • Drumingman
    Drumingman Posts: 348
    edited August 2006
    I prefer a Full Range speaker cause I think the sound is more coherent.
    Nothing wrong with a sub to supplement sound. I think the more woofers you have the better cause it takes a lot air pumping to reproduce good sounding lows. If I had the money, I'd buy Legacy Whispers.
