Problems w/ an old Pioneer amp
nadams
I have a Pioneer amp (model SX-450 See the specs and picture here, courtesy of www.classic-audio.com . The problem I have is that when I turn it on, the front panel lights flicker and I get static out of any of the speakers that are turned on. Sometimes they'll do that for a minute or two, other times they'll only do it for a few seconds. It seems completely random, only that if you had the amp on for a while, turned it off for a second, then turned it back on it'd either not do it all or just for a second or two. I've also had it happen when pushing the amp hard... you know, it's only 15w/ch (a very CONSERVATIVE rating...) and so when I turn it up w/ large speakers the lights dim... well, they were dimming quite a bit, then it just started doing the static and flickering thing. I have a feeling that my capacitors may be going out on me... therefore taking a longer time to get full of power, and when they get drained by loud music it starts the process all over again? Anyone else have thoughts like mine?
I'd like to put this amp into service as my main amp, 'cause I think it'd complement my 5jrs nicely.... right now it's just wasting away in my basement. Please let me know your thoughts... I know you guys and gals know more about this than I do. Thanks a whole heap, man...
nadams
nadams
Ludicrous gibs!
Post edited by nadams on
Just a thought...have you ever taken the cover off and given it a thorough cleaning? It's probably collected a fair amount of dust over the last 20 or so years. I would use a can of compressed air, available at camera stores or Best Buy, and give the guts a good blow. www.partsexpress.com even makes some stuff to spray on the electrical connections to clean them of any oxidation that may have occured over the years. Make sure to unplug it first
becarefull with the spray stuff, you can clean off some plastic coated things inside........the amp sounds like it could use alittle service.If you got a repair shop around your way,I'd stp in for a look see........they could clean it all up and have it sounding like new in no time.........i'd give it a shot!!Dan
GZ- No dust, I cleaned it all out. Also, I bought a can of electronics cleaner from RatShack and cleaned all the connections in the front panel (it made a huge difference w/ the volume and balance knobs... they used to make all sorts of static and cut the channels in and out when turned, but not any more)... but all the connections within the amp are wire-wrapped posts, and I wasn't gonna remove the wire from every single post and clean it, then rewrap. Maybe someday, if it's deemed necessary... At the same time, I might solder them, but I don't want to take away from the authenticity of this amp. I hope to have it for a good long while (even though it's already been around for a good long while). Thanks for your speedy response!
nadamsLudicrous gibs! -
I looked around a bit and didn't see anything that looked like it could be effected, but I really don't know much about these types of things. I think I'm gonna have to hit the yellow pages and see what's around town... I live out in the country, there prolly isn't too many shops... Thanks,
you could have a bad sodder on the wireing for the display and it is causeing noise in the power or the display can be going bad and causing noise in the power with will be herd in the music.
can you dis conect the display if you do and it is going bad that will get rid of the bad stuff or replave the display -
It might be a cold solder joint. This term is meant a couple of ways in audio. In this case, I mean solder that has come loose from its connection (often attributed to cold soldering). If you have the test equipment and an iron you can work it down. Unplug/replug any connectors inside that you can find. If you have my luck and knowledge you'll end-up taking it to a pro. Good luck.Make it Funky!
I'm just spitballing here, but I'm thinking that it MAY be a case of where repairing it would be more costly than the amp is worth. I mean, the cool factor is pretty high and I'm knocking your gear but older 2ch receivers can be had pretty cheap.....
Originally posted by TroyD
...and I'm knocking your gear but....
BDT
NOT knocking? Come on Troy, it's not Dan's receiver....
Cheers,
I was KICKING Dan's gear, remember?
Oh, yeah, sorry, my bad.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
That is very funny!!!! some of you guys have small tiffs i have noticed but its all pretty comical...........MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Thats just what those dudes like to do..........Don't ask me why.Dan
because it's funny, that's why.
nadams,
I gotta agree with Troy. As far as taking it to a repair shop, www.classicaudio.com puts a estimated value on the SX-450 at anywhere between $37 - $67 so I'd be careful what I sink into repairing it. I would think a repair shop is gonna sock you at least $50 just to pop the hood and tell you what might be wrong. I've got a Pioneer SA-8100 integrated amp and TX-7100 tuner from the mid 70's that I still use down in my workshop. They both still work great, but when they don't anymore, they're boat anchors. I couldn't justify putting any $$ into them. As painful as it might be, sometimes we just have to let go. -
You know what Moses said to the Pharoh?
Let my people go...........
its because you guys are butt holes and that is that
damm...freaking horse always kicks himself...what a life!!!
nadams
I would at least give it a try, clean out all the speaker terminals if you can including the terminal on the speaker as well (use cleanning solution from Rat Shak), take out those control knobs on the front panel and use compress air to clean from the inside and outside in those areas, for all other areas, use static-free cloth to clean all the dust out, if all doesn't work, the you need to take the trip to the service dept...good luck... -
Considering the source, I take that as a great compliment
I bet things over on the Def Tech forum are probably pretty interesting.
here is my idea on how to fix your gear take it to a bridge and toos it off then pick up a good used recever that is 15 years old lol
Troy,
I was just wondering.is it because liv4fam owns them or you just have some kind of grudge against Def tech......I was just wondering.Dan
