They are here...
Grimster74
Well, after a long wait (1 week), my new Outlaw gear is here. Once I get everything up and running I'll get back to you guys tomorrw. So, until then, here are some pics.
Post edited by Grimster74 on
Nice!
sweet!
that 990 pre is huge!Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Grimster74 wrote:Well, after a long wait (1 week), my new Outlaw gear is here. Once I get everything up and running I'll get back to you guys tomorrw. So, until then, here are some pics.
Wow! Guys at Outlaw should take as good of pictures. I did not realize that the pre-amp was as large as the amp. With the colored terminals for the pre-outs, it appears that Outlaw was considering THX certification.
Excellent gear. Now give us a review!Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Wow! Very cool.
Mike682 wrote:sweet!
Yeah, it is big but the 7700 damn near out weighs it by about 70lbs. Shipping weight on the 7700 was 107 lbs.Money Talks, Mine says Goodbye Rob!!!! -
damm that amp is huge!! NiceMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Grimster74 wrote:Yeah, it is big but the 7700 damn near out weighs it by about 70lbs. Shipping weight on the 7700 was 107 lbs.
Oh yeah! I can see what looks to be dual torroidals through the top in the 2nd pic.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
I like the looks of the new Outlaw equipment...very clean and much better looking than their original offerings.
I am also on the quest to upgrade HT amps...I also am using a Denon 3803 for our pre/pro,will be glad to hear your thoughts on the differences with your new Outlaw pre. -
Congrats. Nice looking gear.Michael
NORTH of 60° -
Very clean looking. Will be waiting to hear your thoughts.
Nice looking gear. I'd like to hear a review too
Pop the tops and enter those beauties into the guts thread:DReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
I snapped off a couple more pics of the new gear in its new home. Having some real big issues with the pre/pro right now so I'm trying to figure out if it is something I did wrong or if its the pre/pro. It will not let me access any menu options and will not pass any video threw component so I'm not sure what is going on. Anyways, here are some more pics.Money Talks, Mine says Goodbye Rob!!!!
Grim,
Your stuff looks great! I bet it rocks. -
Start with an S video cable for the menu and work it from there...***WAREMTAE***
Grimster74 wrote:I snapped off a couple more pics of the new gear in its new home. Having some real big issues with the pre/pro right now so I'm trying to figure out if it is something I did wrong or if its the pre/pro. It will not let me access any menu options and will not pass any video threw component so I'm not sure what is going on. Anyways, here are some more pics.
I hope you get it worked out. The system definitely looks nice. Now if it will only act nice.
Okay all, my day turned to s@#t real fast this morning. This may be a little long so hang with me. First I get everything hooked up and going this morning and I figured I listen to a CD first before making final adjustments on speakers, etc.. I had a hard time picking my chin up off the floor I was so amazed at the sound that was coming out of those RTi's, singing baby.
Then I decide to get everything dialed inn before really taking a listen. Low and behold, the first problem, not being able to get into the setup menu because the 'menu' button doesn't work. So after switching cables, swapping cables, testing this, that and every damn thing else you can think of I finally narrowed it down to there being a problem with the pre/pro. So what's a guy to do, swap the 990 out for the trusty 3805 as a pre/pro. Once again, I am floored at what I heard, this damn 7700 is a BEAST.
So, after I finally get my chin back in place I then decided to do the speaker adjustments. Front,fine, center,fine, right,fine, right surround, no damn sound, the rest played just fine. So, not only do I have a bad 990, I also have a 7700 amp. with one dead channel. I have (a) checked speaker connections, good, (b) swapped the RS speaker cable with the LS speaker cable and the RS worked, so I know the speaker works (c) replaced the cables with different ones (d) I disconnected all the cables from the Denon, ran a cable from the front right pre-out (which I know works) of the Denon to the right surround on the amplifier and ran the speaker setup again which when it was toggled to the FR, the RS should have played and still no sound. Before anyone asks, I did in fact make sure I switched the amp back to 'unbalanced' instead of 'balanced' when I had the 990 hooked up. I am at the end of my rope. I spent a hell of alot of money on something that doesn't even work properly. I'm guessing I should have just kept what I had and left well enough alone.Money Talks, Mine says Goodbye Rob!!!! -
Don't get discouraged, I know what it's like to spend a small fortune on a piece of gear and have it crap out really fast.
I doubt that Outlaw CS is available till Monday but give them a chance to fix the problem before getting too worked up.
The problems you are experiencing sound bizarre for Outlaw equipment, but if the problem is in fact in the equipment they'll get you fixed up in no time flat. They are on par with Polk CS, IMHO.
Did you connect the preamp to your tv via an S-Video cable as suggested earlier? Was the S-Video output enabled? -
Ditto Frank's advice. I think you'll be feeling quite a bit better on Monday after having spoken with the people at Outlaw. Try to enjoy the system as is until then. Easier said than done, I know, but this will work itself out sooner than later. Awesome looking gear, btw.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Get some pics of the inside when you get time....nice gear, sorry about the problem.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Awesome setup you have there, the gears looks of elegance. I especially like the size of both items. Im sure Outlaw will get you taken care of asap once youre able to dial into them. I was thinking of the 990 myself but the only thing that made we reconsider was the fact there are no HDMI connections yet. Other than that the other Outlaw stuff is awesome, prices are 2nd to none, anyway feel better guy your setup will be on its way soon.
Cheers and have a drink, calm those nerves a tad bit.Shoot the jumper.....................BALLIN.............!!!!!
go the the Saloon on the Outlaw Audio web site. the folks in the forum there are excellent help.. look for gonk. he's one hell of a cool and extremely knowledgeable guy on all Outlaw Audio gear.
often times it's just a setting or bad cable somewhere. i have the 990 pre as well.. and while I have not had any malfunctions with it.. there have been many times when a setting was incorrect.. and it sounded like crap.
are your interconnects good? Not just the whole lot.. but one out of the many you have in your system may be shorted out or bad. tear down your system and start from scratch... isolate the problem.. then add component by component and find out what piece is causing the problem.PolkFest 2012, who's going>?
I am totally jealous, nice purchase!// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
// Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
// Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
Photo Gallery
Movie and Game Collection -
SUCH a beautiful thing Yamaha RX-V2600
Adcom GFA555 x 2
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects -
Okay, is it possible to have a bad 'unbalanced' connection on an amplifier and have a good 'balanced' connection? The reason I'm asking is I hooked the 990 back up to do some more trouble shooting. Here is what I did, I just hooked up 2-channel. I first hooked the left front up as it should be, left 'balanced' out to the left 'balanced' in on the amplifier. I then hooked the front right 'balanced' out of the pre/pro to the 'balanced' left surround in on the amplifier and then hooked the FR speaker wires into the SR speaker input and the SR channel, which did not work earlier today, worked just fine. Is it that I may just have a bad 'unbalaced' connection on the SR channel?Money Talks, Mine says Goodbye Rob!!!!
They are meant to be individual signal paths by design, so sure, you COULD have a single, bad connection.
Just isolate the problem, word it and let Outlaw handle the rest.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Well the amp situation has been confirmed by my standards. The "unbalanced" connection on the surround right is in deed bad. Lets just hope Outlaw will make good on the CS and send me a replacement of both the 990/7700, then once I receiver them, send the bad units back.Money Talks, Mine says Goodbye Rob!!!!
umm. i think they want the bad units back before they will send you the new ones.. i could be wrong.. but that's how most places do it.
well glad you made some progress.. how about the menu? Can you still not get into the menu?PolkFest 2012, who's going>?
Still can not get into the menu.Money Talks, Mine says Goodbye Rob!!!!
