Dual Subwoofers vs Single
SolidSqual
SolidSqual Posts: 5,218
edited August 2006 in Speakers
Hey Guys (and maybe some gals)
I'm currently running two SVS PB10-NSDs. I have stacked one on top the other right next to my couch. I bought both of these because it was a lot of bass for a little bit of money. Now, I'm thinking of transferring one of my PB10s to a bedroom system and adding a PB12 plus 2. Is this advisable? or would the different driver sizes disrupt the overall quality. I'm not a bass fantatic, I just like deep clean gut kicking action when I'm playing video games or watching movies. Should I consider a cylinder alternative? I was told the cylinder subs are less effected by room placement. Is this true? Finally, does anone have any experience with how the PB12 plus 2 may sound compared to two PB10s stacked? I just want a general idea of how strong the beast may be.
Post edited by SolidSqual on
  • EricBurg
    EricBurg Posts: 64
    edited August 2006
    Are you unhappy with the way the pb10's sound together?
    The plus 2 should outperform the 2 pb10's.
    Eric
    __________________
    Pioneer 1015
    Rotel 1080
    Rotel 1075
    Rti10: L/R
    Rti5: C
    Rti6: LS/RS/LSB/RSB
    SVS pb10-isd
  • SolidSqual
    edited August 2006
    No I'm actually very satisfied, but I wondering if there would be a considerable difference. If there isn't then I'm just going to buy another PB10 for the bed room.
  • Demiurge
    Demiurge Posts: 10,874
    edited August 2006
    Did you try calling SVS and discussing it with them? I have talked to them a few times, and it's been my experience that they're honest and won't try to upsell you for the sake of an extra buck.
  • MattN03
    MattN03 Posts: 558
    edited August 2006
    I agree, everyone I've dealt with at SVS will shoot it straight everytime. They're a great company to work with. :) Give 'em a call!
