Flexy Rack Feet ???
dipiazza
Hey im building a flexy rack. Just a small 2ft one, withe 1/2'' threaded rods.
I was looking for something to go over the threaded rodds on the bottom feet, something like a rubber foot. What do you all think about these?
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-774
Would they fit over a 1/2'' threaded rod?
Does anyone have any other ideas from experience?
Thanks!
Thanks!
Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
HT Setup
TV: Vizio VX32L
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
2CH Setup
Headphones
Other Stuff in Use
Post edited by dipiazza on
I used accorn nuts, work well on carpet, similar to spikes
Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
^^ I bet that would work well on carpet. I'll add 5 of those to my parts list. Hmm, what about the tops...maybe I oughta make it 10...
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
My flexi rack was going on carpet,so i just used a bench grinder and ground a
V point on the bottom end of each rod. Cheap and easy. I couldn't find acorn
nuts in the 5/8" size. For the top, I used nuts with the rubber insert to keep them from loosening up. They also have a slight taper, which looks better, too.
I did the one off style, where you cover the 5/8" rod with 1/2" painted PVC
pipe."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Accorn nuts work great- Just don't pay too much. HD has two kinds, one is like $1.50 for six, one is like $1.50 each (zink vs Stainless, IIRC). The cheap ones are fine. Oh and if you grind them down- thread them onto some spare rod. I nearly lost an eye when a nut popped out of the vice grips I was holding it with and went flying around the room.
I think those rubber feet only have a small hole in the center (big enough for a wood screw), so you'd have to figure out a way to grind out the center with out shredding them.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i
