Flexy Rack Feet ???
dipiazza
dipiazza Posts: 363
edited August 2006 in DIY, Mods & Tweaks
Hey im building a flexy rack. Just a small 2ft one, withe 1/2'' threaded rods.
I was looking for something to go over the threaded rodds on the bottom feet, something like a rubber foot. What do you all think about these?
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-774
Would they fit over a 1/2'' threaded rod?
Does anyone have any other ideas from experience?
Thanks!
Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
Post edited by dipiazza on
  • tryrrthg
    tryrrthg Posts: 1,896
    edited August 2006
    I used accorn nuts, work well on carpet, similar to spikes
  • audiobliss
    audiobliss Posts: 12,518
    edited August 2006
    ^^ I bet that would work well on carpet. I'll add 5 of those to my parts list. Hmm, what about the tops...maybe I oughta make it 10...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • sucks2beme
    sucks2beme Posts: 5,693
    edited August 2006
    My flexi rack was going on carpet,so i just used a bench grinder and ground a
    V point on the bottom end of each rod. Cheap and easy. I couldn't find acorn
    nuts in the 5/8" size. For the top, I used nuts with the rubber insert to keep them from loosening up. They also have a slight taper, which looks better, too.
    I did the one off style, where you cover the 5/8" rod with 1/2" painted PVC
    pipe.
  • unc2701
    unc2701 Posts: 3,587
    edited August 2006
    Accorn nuts work great- Just don't pay too much. HD has two kinds, one is like $1.50 for six, one is like $1.50 each (zink vs Stainless, IIRC). The cheap ones are fine. Oh and if you grind them down- thread them onto some spare rod. I nearly lost an eye when a nut popped out of the vice grips I was holding it with and went flying around the room.
    I think those rubber feet only have a small hole in the center (big enough for a wood screw), so you'd have to figure out a way to grind out the center with out shredding them.
    Backburner:Krell KAV-300i
