Should work be able to dictate your life?
My hand was forced (where, I won't say)....
comment comment comment comment. bitchy. -
Warren: In some cases yes, in others no. If you are one of the top 1-5% in your field, you will be limiting yourself and your bargaining power by organizing. For a majority of people, you are right, but the unions tend to try and normalize out pay scale and compitition which is good if you suck, but bad if you're one of the best. Thanks for the reply.
If you are the best, and the Co. recognizes it they can pay you more if they choose to do so, they can't pay you less, if you meet all the requirements of that pay scale. If the employee sucks, witch means the Co is required to take action, Mgt., the employee and the Union meet, get the employee back on track, or face the consequences, according to the negotiated agreement. If everything works out fine, it's a win win situation.Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
Omg!!!...thudMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Stop it Brett, I'm getting all sweaty.
