speaker connections
jdannyj
jdannyj Posts: 26
OK this is probably a stupid question...but.
I'm wondering about speaker cables. My receiver (sony str-da2000es) does'nt take the speaker cable as it comes, I have to cut the cable and just feed the cable into the holes on the back of the receiver... This is the same with my polk center speaker and it's connection. I just wanted to make sure i was'nt doing anything wrong when making these connections.
Post edited by jdannyj on
  • michael_w
    michael_w Posts: 2,813
    edited July 2006
    Were the ends of the cable terminated with banana plugs, spades or anything else? There are others such as pins and bfa's but they're less common.
    As long as you're keeping positive with positive and negative with negative it doesn't matter if you're using bare wire or some kind of termination. I personally use banana plugs because they're much handier to swap gear out if I want to. When you use banana plugs you will probably have to take out a small plug that covers the hole.
  • Willow
    Willow Posts: 11,231
    edited July 2006
    I have those exact nanner plugs
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited July 2006
    Yup... I've had 'em. Blue Jeans Cable keeps them in supply, as does Parts Express. They're pretty heavy duty, and the floating slug makes for a tight fit.
  • jdannyj
    jdannyj Posts: 26
    edited July 2006
    thanks for the response. I just wanted to make sure i was'nt doing anything wrong. it looks like i am..
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2006
    I have a Sony 7100es and Im using the same banana plugs as shown above. Im using them on both the receiver and all speakers. They provide a nice and snug fit as well, perfect for the Sony ES line as the others have noted.
  • jdannyj
    jdannyj Posts: 26
    edited July 2006
    I've always just cut the end off the cable, and used the bare wire...
    I've just purchased monster cable z2 reference ML-C10 cable for my center speaker.
    (sorry, not sure how to add pictures,) would i be right in cutting off the end and just inserting the bare wire into the terminals?? I just want to make sure i'm getting the best connection for the best sound..
  • Sherardp
    edited July 2006
    they say the best connection is bare wire, but I just choose to use the Banana Plugs, its just an easier life and if I do lose some quality Im sure its so minimal I cant tell. But yeah you should be able to cut(splice at the end) and insert the bare wire into the terminals.
  • jdannyj
    jdannyj Posts: 26
    edited July 2006
    thnks for the response.I will just have to see what happens..the cable should arrive in a few days, so hopefully once connected i will here the difference.
  • Sherardp
    edited July 2006
    getting that speaker wire into the Sony Es is somewhat difficult that is why I went with the B plugs. Let me know how this works out for you, check parts express they have various terminations that might work for you as well
  • michael_w
    edited July 2006
    If they're already terminated with nanners or spades I say just leave them that way. Using bare wire is supposed to be the best connection but i can't tell the difference. Bare wire also oxidizes over time so you'll have to keep cutting it back as well as if you swap out your speakers often.
  • jdannyj
    jdannyj Posts: 26
    edited July 2006
    so when i use the banana plugs,or spaded ends, do i just unscrew the nobs, and insert the pin into the hole, then just screw back the nobs??sorry for the stupidity, i have always just used bare wire...
  • Sherardp
    edited July 2006
    get the banana plugs, unscrew them enough so the slug inside will slide down. Feed your speaker wire through and tighten the bottom up. Make sure your speaker terminals in the back of the receiver aretightened back up, insert the Banana plugs into the corresponding terminals and youre done.
