Monitor 5 Series 2...what ohms?
jeffandpamsmith
jeffandpamsmith Posts: 7
edited July 2006 in Vintage Speakers
I have an old pair of M5 that I want to set up with a refurbed Onkyo for my mom. She'll only use FM or CD and never crank it up.
The Onkyo is a TX8011 with 50watts/channel but doesn't say its 6 or 4 ohm capable.
I searched here, but couldn't find the answer easily. If I recall the speakers are 6 ohm. I just din't know if the Onkyo will trip under this circumstance or if I'm over-worrying.
Post edited by jeffandpamsmith on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited July 2006
    Hello,
    Any solid state receiver is fine with speaker impedances from 4 to 16 Ohms. That's the nice thing about transistors, they have low output impedances and can develop power into a wide range of loads. Some times receiver manufacturers specify a certain load to allow the unit to pass certain temperature requirements. The Monitor 5 will have a nominal impedance of 6 Ohms and should be fine. If the receiver is used with a low impedance, say below 3 Ohms, at fairly high volumes it will have to produce higher amounts of current (gallons-per-minute) which, in turn, increases heat and could trip any protection circuits. Lower the volume and all's well.
    Enjoy, Ken
  • QuistQuest
    QuistQuest Posts: 14
    edited July 2006
    I'm really pleased with the Klipsch/KEF combo I have with my main stereo.
    However, for my office stereo, I just picked up the set of RTA 8TLs someone on this site had pointed out. (got them, then saw the post that evening when I got back.)
    I've had a set of M7s for for decades (they were built in 91)
    The third set is Pioneer CS-722s.
    My question: What is the best two-speaker type combo and why?
    Also, I looked for info on the RTAs on this site and didn't find much.
    What are the highlights and lowlights with them?
    thanks,
    dennis
  • QuistQuest
    edited July 2006
    I'm overwhelmed by the "talent" on this site and underwhelmed by its management. too many rules, and too cumbersome an interface. now I'll go repost, under a new thread.
