bi-wire with 2 amps
ronnie
whats up fellas, heres the situation.....i already have my speakers bi-amped....now im getting another gfa 555. i want to use the amps in mono mode and get the high watts for my rti12's. they sound good now but i know they can sound better....i like and listen to my music very LOUD....right now i have my other adcom running the woofers and its not as much bass as i expected...so should i reconnect the jumpers and mono the amps or is there a way to mono and bi-wire ....im kinda confused on how to make the best of the 2 amps... any suggestions would be greatly appreiciated
Yamaha RX-V2600
Adcom GFA555 x 2
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects
Post edited by ronnie on
come on guys....need some info......im bidding on this amp on e-bay and really need some answers before i bid any higher.......thanxxxYamaha RX-V2600
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects -
Biamp the left rti12 into one gfa-555, and the right rti12 in the 2nd gfa-555.
That's 400 x 2 into 8ohms, and 650 x 2 into 4ohms. That should be enough for your needs.
http://www.stereophile.com/solidpoweramps/678/ -
thanks for the linkYamaha RX-V2600
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects -
Ronnie, those 12s will sing like no other, Im bi-amping my 12s with two Outlaw M2200 monoblocks and a Sony 7100 ES, and that to me can get very loud. I can only imagine what youre experiencing. Happy Listening pal. WOWShoot the jumper.....................BALLIN.............!!!!!
Hey,,sherardp....hows The Bass In Your 12's Sound...i Dont Think Its What I Expected...a Little Weak To Me...very Accurate, But Not As Forceful As I Thought It Would Be...i Did Move Up From A Set Of Cerwin Vegas With 15 Inch Woofers....im Probably Just Used To Booming, None Accurate Bass....you Really Have Some Nice Gear, I Know Your Enjoying It.Yamaha RX-V2600
Adcom GFA555 x 2
Polk RTi12 mains
Polk CSi3 center
Polk psw303
blue jeans cables
AR interconnects
