Outdoor fireplace options
steveinaz
I know, it's a 110 degrees out--just planning ahead. Do any of you have stone/brick/cinder block outdoor fireplaces? Was it a DIY'r project or did you have it built? Cost? Pics?
Most importantly...ideas?
We have a fire pit made from a large copper tub unfortunatly, we have not had the backyard finished enough to sit out there and enjoy it. (we are getting a pool built right now)
I am sure it will work great and it is not permanent.
I have seen really nice ones at the outdoor store owned by the pool company building ours. (Aqua pools)
They have pre-built units that they install and finnish in the tile or stucco you want.
Prices are a little high IMO but they sure look nice.
Sorry I have no pics.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
I am thinking about doing something like this...
http://www.diynetwork.com/diy/shows_droc/episode/0,2499,DIY_21539_37345,00.html
I won't use flag stone but figured the .99 cent yard pavers would do just fine.
HBomb***WAREMTAE*** -
Cool!
Pavers would be a heck of alot easier to maintain level as well.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
That looks nice, I may try to "build in" my copper pot someday.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
My brother and I built something sorta like that at his place. Getting the consistency of the mortar right is key... and I have no advice on how to do that. We'd mix it up, put in a few stones, decide something was wrong, add more mix or water, mix it up again (BTW renting a mixer is a very good idea), then try again.
Turned out OK, but for all we know if could be crumbling in five years.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
This is the kind I want.
Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Its small and dinky, but sort of cute, we are thinking about one of those round tables with a small fire cage in the center. I doubt it puts out much heat, but its an option.
I was just gonna make a permenant firepit
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Patrick & I are gonna have to bring the girls up there and get the sucker built.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
