Outdoor fireplace options
steveinaz
steveinaz Posts: 19,545
edited April 2024 in Clubhouse Archives
I know, it's a 110 degrees out--just planning ahead. Do any of you have stone/brick/cinder block outdoor fireplaces? Was it a DIY'r project or did you have it built? Cost? Pics?
Most importantly...ideas?
  • Skynut
    Skynut Posts: 2,967
    edited July 2006
    We have a fire pit made from a large copper tub unfortunatly, we have not had the backyard finished enough to sit out there and enjoy it. (we are getting a pool built right now)
    I am sure it will work great and it is not permanent.
    I have seen really nice ones at the outdoor store owned by the pool company building ours. (Aqua pools)
    They have pre-built units that they install and finnish in the tile or stucco you want.
    Prices are a little high IMO but they sure look nice.
    Sorry I have no pics.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • HBombToo
    HBombToo Posts: 5,256
    edited July 2006
    I am thinking about doing something like this...
    http://www.diynetwork.com/diy/shows_droc/episode/0,2499,DIY_21539_37345,00.html
    I won't use flag stone but figured the .99 cent yard pavers would do just fine.
    HBomb
    ***WAREMTAE***
  • steveinaz
    edited July 2006
    Cool!
    Pavers would be a heck of alot easier to maintain level as well.
  • Skynut
    Skynut Posts: 2,967
    edited July 2006
    That looks nice, I may try to "build in" my copper pot someday.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • unc2701
    unc2701 Posts: 3,587
    edited July 2006
    My brother and I built something sorta like that at his place. Getting the consistency of the mortar right is key... and I have no advice on how to do that. We'd mix it up, put in a few stones, decide something was wrong, add more mix or water, mix it up again (BTW renting a mixer is a very good idea), then try again.
    Turned out OK, but for all we know if could be crumbling in five years.
    Backburner:Krell KAV-300i
  • Skynut
    Skynut Posts: 2,967
    edited July 2006
    This is the kind I want.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • Skynut
    Skynut Posts: 2,967
    edited July 2006
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • Shizelbs
    Shizelbs Posts: 7,433
    edited July 2006
    Its small and dinky, but sort of cute, we are thinking about one of those round tables with a small fire cage in the center. I doubt it puts out much heat, but its an option.
  • I-SIG
    I-SIG Posts: 2,243
    edited July 2006
    I was just gonna make a permenant firepit
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • steveinaz
    edited July 2006
    Patrick & I are gonna have to bring the girls up there and get the sucker built.
