New Vs. Old -- LSi
Demiurge
Demiurge Posts: 10,874
edited July 2006 in Speakers
I need to know how big a deal it would be if I paired old LSi speakers with the new ones in a 5.1 or 7.1 system. I was reading the manual on my LSiC (new version), and it seemed to poo poo doing that. How big of a deal is it really, and will it screw things up? I'm getting close to purcasing either some LSi9, or LSi15.
Sorry if this has been covered before, but I turned up nothing in a search.
Thanks!
Post edited by Demiurge on
  • pjdami
    pjdami Posts: 1,894
    edited July 2006
    See Tour's response in the thread below. At one of the PF, Stu from Polk said the change was cosmetic only.
    That has been my understanding all along too. If you do an advanced search Lsi+new you will get more hits along the same lines.
    Are you keeping the fronts all the same at least or will the center be the new one? I think you'll be okay.
    http://www.polkaudio.com/forums/showthread.php?t=16904&highlight=lsi
    F1nut Posts: 51,997
    edited July 2006
    pjdami wrote:
    ......the change was cosmetic only.
    That would be correct.
  • Demiurge
    edited July 2006
    I'm not even using my LSiC right now. I'm still using my CSi40. I'm going to move the LSiC in when I get LSi15s or the LSi9 (I plan on getting both in the end) and will live without surrounds until then.
    I just wanted to know so that if I see someone selling them I don't have to gripe over new vs old. It's nice to know it doesn't matter.
    Thanks for both of your responses.
  • SKsolutions
    SKsolutions Posts: 1,820
    edited July 2006
    +1 on the belief that there were no driver or xover changes.
    -Ignorance is strength -
