Rti series bad in music?
KrazyMofo24
KrazyMofo24 Posts: 1,210
edited July 2006 in Speakers
Setup:
Rti10's
Csi5
Fxi5
Rti4
h/k 335.
How well do the Rti10's mainly fair in music compared to most speakers in the same price range? I have listened to several different speakers, but all were in lower end range. I was able to afford these because I got a discount at Fry's. Reading through the forums when compared to the lsi's they are only good in movies. Movies i'm completly satisfied however I feel music could sound better. Right now the speakers are bunched up in a small room which I know affects the sound but it doesn't seem it should for just 2-channel music. Can adding a good amp improve the mids any? And is the Rti series a good choice for listening to music 85% of the time compared to other speakers in the same price range?
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
Post edited by KrazyMofo24 on
  • dale 442
    dale 442 Posts: 98
    edited July 2006
    Power, power, power.
    I'm a big fan of HK but the 10's need more if you want them to really come alive. See my RTi 4's with Carver review in this forum.
    Enjoy
    Dale
    Polk SDA 2B's
    Carver TFM-45
    Sony X33ES CD-direct to Carver
    Samsung 4051D 40" LCD
    Samsung DVD
    Paradigm PS-1000
    Denon 1507 A/V receiver, video only
    Rti4's Front and Rear, video only
    CSI3 center, video only :rolleyes:
  • KrazyMofo24
    edited July 2006
    A 2-channel amp is what I'm saving for, if the Rti10's can sound as good as the Martin Logan's Clarity's I heard at Magnolia with their $1,500 amp, well atleast come close I'll be happy.
    Setup:
  • Demiurge
    Demiurge Posts: 10,874
    edited July 2006
    The LSi line is the best for music, but the RTi should do you fine for now. I do agree that you need to feed them lots of juice if you want the puppies to sing.
  • dale 442
    dale 442 Posts: 98
    edited July 2006
    I'm not sure if they can do that, only you will be able to make that call. Keep saving, I do believe you will get what you are after using a good powerful amp to run the 10's up front through the HK.
    Dale
    Polk SDA 2B's
    Carver TFM-45
    Samsung DVD
    Paradigm PS-1000
    F1nut Posts: 51,689
    edited July 2006
    IMO from the ones I heard, they were designed for HT, not music. The top end is too bright.
  • mmcgehee
    mmcgehee Posts: 64
    edited July 2006
    I would be inclined to agree, while music doesn't sound bad it obvious these speakers weren't designed for music.
  • keith allen
    keith allen Posts: 734
    edited July 2006
    I also agree,I changed my preamp,and cd player,and also did an upgrade on the cd player,and it help the harsh highs...somewhat.
  • Willow
    Willow Posts: 11,218
    edited July 2006
    I would not say they are bad, as they are not bad speakers, not at all. it may not be their forte.
  • Systems
    Systems Posts: 14,873
    edited July 2006
    i totally agree
    Testing
    Testing
    Testing
  • KrazyMofo24
    edited July 2006
    I knew I should have gotten the Lsi's when I had the chance...my issue at the time was cost, mainly the cost of a good amp for the Lsi's. I will probably keep my Rti system, buy a good amp see if it helps if not i'll start saving for a pair good towers.
    Setup:
  • bertram
    bertram Posts: 53
    edited July 2006
    Your RTi system is great, but primarily for what it was designed for... HT. LSi speakers are much better for music (due in large part to the high-end tweeters) but in my experience too laid back for HT. I used to have an all-LSi HT system but found movies sounded somewhat lifeless and, more importantly, the dialog hard to understand. I then moved the LSis to a multichannel music system, where they sound great, and got the RTis for HT. I think I won't be upgrading for many years.
    Multichannel Music:
    Sony SCD-C2000ES SACD
    Denon 3803 AVR (pre/pro duty)
    Outlaw 755 amp
    Outlaw ICBM
    Polk LSi15/LSiC/LSi9 (front/center/surround)
    SVS PCU
    HT:
    Sony 9100ES DVD
    Outlaw 990 pre/pro
    Outlaw 7100 amp
    Panasonic TH-37PX50U plasma
    Polk RTi8/CSi5/RTi6/FXi5(front/center/surround/back)
    SVS PCU
  • PolkThug
    PolkThug Posts: 7,532
    edited July 2006
    Almost any speaker could be considered "bad for music". It just depends on your personal experiences and perspective.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited July 2006
    I personally don't care for the Rtis in music one bit, but I have yet to use proper amplification on them as well. They are great in HT though.
  • KrazyMofo24
    edited July 2006
    Any suggestions under $1,000?
    Setup:
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited July 2006
    I think to expect the Rti10's to come even close to the ML Clarity's is overly optimistic. Whole different type of speaker as well as price class.
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • KrazyMofo24
    edited July 2006
    When I was listening to the Clarity's I was comparing them to the Lsi15's before I made my decision to go with the 10's. I know the Clarity's are over twice the price since rti's are geared towards HT. Anyone have recommendations for a pair thats great in music, mids most importantly under a grand price range?
    Setup:
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2006
    Since my esteemed colleague's missed your question, when compared to other speakers in the SAME price range the RTi are better for music than say the others, of course this is subjective opinion, however, I am right.
    Just build two system and get it over with, you will be broke but happy and you can hang out here for free.
    get some, lets see, manley amps, mono blocks, for power, then a nice player with discreet circuitry for redbook and SACD, say something by Musical Fidelity or other such comparable product, then a nice Pre with extended bandwith, maybe a BAT, and OH, definetly a TT to get your old school on, a nice VPI, Rega or such, and then a phono pre, I like the Acoustech I have for that, then of course wire a solid rack and your done!!! see simple of course you still need to buy the speakers cuz the RTi will no longer be getting it done for you.
    Oh yea, if you have wife, you have to buy her something too so add the cost of that in.
    RT1
  • Lowell_M
    Lowell_M Posts: 1,660
    edited July 2006
    I am quite happy with my RTi's and H/K for music, but have read that the H/K is a warmer sounding AVR than others, so maybe it takes some of the harshness out of the RTi's. Of course...my experience is a little limited since I haven't heard a very wide variety of other systems.
    Try the amp and see how you like the sound. If your still don't like your RTi10's for music, you still should see an amazing improvement in sound for HT. Build from there with LSi's in a 2-channel system.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • aaharvel
    aaharvel Posts: 4,489
    edited July 2006
    My AVR coupled with the 2.1 takes my otherwise bright-sounding speakers into a territory of neutral/warm, even in 2ch. It's all about proper matching - exposing strengths of one piece while offsetting weaknesses of another. Overall, if done right, the 4 and 10 imo are the best in the RTi line, though not on the same level as anything LSi. To my ears, the older Rti's/Tri-lams were awful for everything short of HT.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • KrazyMofo24
    edited July 2006
    Went over to Magnolia today after work only audio shop near me. I thought the Boston Acoustics VR3 sounded great it was powered on a Denon receiver. Well it took me awhile just to pay for the system I have now and got it under a grand($600 speakers $350 receiver) thats the sad part. Well I want to buy a good amp first, then save for either the Lsi15's or another pair in $2,000 range. To save me the trouble of having to buy another amp whats the price range should I look at for a good amp that'll power the 10's and be good enough for better speakers later?
    Setup:
  • reeltrouble1
    edited July 2006
    Well dont know why you would not want the Manley mono blocks, but then the Parasound JC-1 blocks are nice, how much do you want to spend on these amps? Do you have to worry about a WAF??? Do you want only new or is used a consideration? Otherwise your going to get the usual long list of suspects, all high current which is what you really need.
    RT1
  • wallstreet
    wallstreet Posts: 1,405
    edited July 2006
    I use my RTi6's exclusively for music and you know what, they sound great. This talk about good for HT bad for music is baloney. A speaker either has a flat response curve or it doesn't. The flatter the better. If you don't like speakers for music I don't see how you could like them for HT.
    F1nut Posts: 51,689
    edited July 2006
    Bright/detailed speakers are better for HT, not so good for music, IMO and a flat response curve alone does not make a speaker good.
  • bertram
    bertram Posts: 53
    edited July 2006
    I have the RTi6s, as well as the LSi9s, and you know what, the LSi9s are much better sounding for music. The RTi6s, in comparison, sound overly bright and edgy. Maybe the folks at Polk knew what they were doing when they upgraded the tweeters in the LSi series to the ring radiators?
    However, as we are all accustomed to aggressive, bright sound in movie theaters, maybe this is the paradigm Polk followed when designing the RTi line. I think the RTis sound "natural," or at least consistent with the movie theater experience, when reproducing movie material, but unnatural when reproducing music.
    Multichannel Music:
    Outlaw 755 amp
    Outlaw ICBM
    SVS PCU
    HT:
    Sony 9100ES DVD
    Outlaw 990 pre/pro
    Outlaw 7100 amp
    SVS PCU
  • wallstreet
    edited July 2006
    You can't compare LSi's with RTi's. They're not in the same league. That's like comparing SVS 20-39 to polks 10" subwoofer. Yea, they're both subwoofers, but that's about where the similarity ends.
  • wallstreet
    edited July 2006
    IMO, natural sounding speakers are better than bright sounding speakers, regardless of use. And true, I am simplifying what makes a good speaker good for the purposes of brevity.
    F1nut Posts: 51,689
    edited July 2006
    I agree 100%. It would seem that Polk and other speaker companies are designing bright speakers aimed mainly at HT users. Perhaps to compensate for the short comings of entry level AVR's. However, I can certainly respect that you enjoy them for music.
    Got ya! :)
  • reeltrouble1
    edited July 2006
    I guess it depends on your defintion of bright. Which is oft times used around here as something that is a bad thing. I dont think bright is bad, just like I dont think warm sounding is bad, harsh bright is bad on the upper end, and muddy warm is bad on the lower end, so the RTi tend towards the bright side and the LSi to the warm, Kapish??????
    So since movies are comprised primarily of Dialogue and noises with music used as a backdrop RTi series does well with that software. I used RT for music for a while, its not that they sound bad, there are just speakers that sound better for music, afterall, RT is short for Reference Theater.
    That is it.
    RT1
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2006
    Rti bad for music I say not. I enjoy my RTi150 over my old Rt800i speakers for music. Rti have a soft dome tweeter the RT speaker have a tri-lam tweeter, the Tri-lam is listening fatiguing the RTi tweeter is not. May not be the best speaker for music, but not a bad speaker either.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
