Amp choice advice
  • markeddie
    markeddie Posts: 23
    edited July 2006
    Thanks to all for your time and advice, it is much appreciated. The next question is how to listen to different amps. Going to stores and listening to their products with their speakers, will this be comparable to the same amps with SDAs? And I seem to be limited to a few specialty high-end audio stores, the big box stores don't have anything high-end.
  • markeddie
    markeddie Posts: 23
    edited July 2006
    I think I have guessed that part of this journey is trial and error. It's why you see people selling used equipment because they found something they liked better.
    F1nut Posts: 51,767
    edited July 2006
    Most high end shops will let you try an amp or any piece of gear at home with your credit card as security.
    SCompRacer Posts: 9,112
    edited July 2006
    +1
    I have a friend that is into audio and lives nearby. We have swapped gear between us to try in our environment. The other paths are as F1nut suggested, or you buy used gear at fair prices and resell if you don't like it. The latter suggestion adds complexity and risk of course.
