Bose AM 10 VS Polk RCi65 Surround
cgmckenzie
Purchased a Bose AM10 system have not hooked it up yep. Following the hype i think i screwed up. Read some bad reviews after the fact. Couple of questions the bose surround speakers hook up threw the sub. If i change systems and go with the polk RC65is for surrounds and the PSW303 for the sub do the speakers wire into the sub are the reciever. I have Polk RT2000 for music, love them, with a Sony STRDE975 reciever. Also how would this polk surround system compare to the Bose. One last question on the website why does the LC265i surround system not have a subwoofer recommended. On that system the front and center speakers are rectangler while the rears are round looks wierd can u use the LC265i for rears also. Any help would be appreciated thanks Im a surround Novice Chris Mckenzie
Post edited by cgmckenzie on
Welcome to Club Polk!
Sorry for the bad news but your Bose are way over priced and you could probably do a lot better with a lot less money. I suggest the Polk RTi line of speakers. What kind of receiver do you have and what is your budget? Are you looking for just HT or do you also listen to a lot of music? Welcome!:)Carl -
you should take the bose back. I dont see any problem with using the inwalls for rears, of course installation, adjustment issues would have to be overcome.
RT1
