Towers............?
Welcome to the Club Polk Forums jdannyj! Do you have the center channel level adjusted? I would turn up the center channel level to get a better blend. The matching speakers will get you a better timbre match and this may help. But I would start with channel adjustments. Good luck and welcome to Club Polk!Carl
Hi & welcome. Go into the speaker settings for the receiver & bump up the volume for the center channel a couple of notches, but leave all the other speakers where they are.
This is a common complaint for just about all center channels!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
