what are the effects on amp due to biwiring?
multifidus11
multifidus11 Posts: 10
Can anyone tell what biwiriing does to impedance, current, and wattage of the amp?
Post edited by multifidus11 on
  • jegs
    jegs Posts: 15
    edited June 2006
  • dragon1952
    dragon1952 Posts: 4,940
    edited June 2006
    That is correct. The amp still sees the same load.
  • ward91
    ward91 Posts: 338
    edited June 2006
    if you think about bi wiring all it does is moves the brige of the tweeters and the bass/mids to the back of the amp rarther than those stupid annoying little metal things
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • multifidus11
    edited June 2006
    thats what i was thinking. how does biwiring bypass the internal crossover that is inside the speaker? really if you do biwire or biamp shouldn't you remove the crossover?
  • janmike
    janmike Posts: 6,146
    edited June 2006
    So have you folks noticed any huge difference using jumpers as opposed to bi-wired cables? I am currently using Signal Cable Ultra Speaker Cables and I was thinking of purchasing some jumpers instead of new cables that are bi-wired. I will be using them on the LSi9's. Noticed some Mathura audio Premium Bi-Wire jumpers and wondered if they were any good.
    Michael ;)
    NORTH of 60°
  • honestaquarian
    honestaquarian Posts: 3,260
    edited June 2006
    It doesn't bypass the crossover.Only active biamping does that.Active meaning you are using an external electronic crossover and sending the band limited signals from the crossover to each amp.
  • multifidus11
    edited June 2006
    if one does actively biamp with an external crossover and multipule amps, would it then not be wise to remove the internal crossover entirely?
  • honestaquarian
    edited June 2006
    Yes,but you would be HARD PRESSED to find all of the mentioned components nowadays.
  • unc2701
    unc2701 Posts: 3,587
    edited June 2006
    You'd be hard pressed to find them cheaply, but active and pseudo-active crossovers aren't that hard to come by. Anyhow, you could remove the crossover entirely, but you'd probably want to put back in a zobel network- it levels off the speaker impedence.
    Backburner:Krell KAV-300i
  • honestaquarian
    edited June 2006
    Fascinating.
  • ward91
    ward91 Posts: 338
    edited June 2006
    just bypass the crosover because inside of my speakers the crossover is screwed onto the binding posts, just undoo it cut the conections and re conect them
    but yes crosovers do change impedence but if you are patient active crosovers arnt expenisie on ebay
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • multifidus11
    edited June 2006
    how is the quality of polks crossovers inside the RTi 12, CSi5, and FXi5. This being my system i am upgrading amps and am deciding what route i want to go:either with an external crossover and multiple amps or a good preamp and multichannel external amp. if i go with say the outlaw pre990/7700amp. should i just biwire and upgrade the internal crossovers, or should i go another route? i would appreciate suggestions i would like to keep the amp upgrade to no more than $5000.
  • ward91
    ward91 Posts: 338
    edited June 2006
    i think i would just leve the inerds alone and just bi wire it all . to say i joined polk audio i dont know a lot about polks, so i could be wrong. i know some people upgrade crossover components, thats not expensive at all
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • ohskigod
    ohskigod Posts: 6,505
    edited June 2006
    new speaks? I say abandon the external crossover/active biamp thing.
    I say go the outlaw route, I've never had an outlaw piece let me down. (great quality/great price)
    Leave the crossovers alone dude. you will void the warranty I'm sure, and will probably be surprised as to what good external amplification will do for those speakers, particularly the RTi12, which is known to be a bit power hungry. Biwire is perfectly fine, remove the jumpers of course, but I'm sure you allready knew that
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • multifidus11
    edited June 2006
    i like your set up and i am not sure if i should use a variety of different external amps or just the outlaw 7700, with wattage a little low for the rti12s and a little to high for the fxi5. any sugguestions about how to approach this. i really want to make the rti12s sing, but don't want to fry my surrounds if i crank it in 5 channel stereo?
  • ohskigod
    edited June 2006
    you wont fry the surrounds just by virtue of overpowering. by far, underpowering a speaker is more dangerous than overpowering (due to the amp clipping = nearly instant fried driver)
    I dont know if the outlaw your looking at is 5 or 7 channels. if it is 7, then biamp the main with 4 total channels, and then use the others for the center and surrounds (in a 5.1 system)
    even if you go 7.1 channel down the road, just pick up a couple of the outlaw monoblocks, and voila.
    if the amp your looking at is 5 channel, I'll say that having the same power going to the RTi12 and the surround speaker is really no big thing. makes calibration a little easier most likley. again, if your worried, just pick up a couple of the outlaw monoblocks and biamp the mains with 2 channels of the main amp.
    in summary, if your running 5.1, you would need 7 channels of amplification under this plan (the mains biamped = 4 channels, center = 1, surrounds = 2)
    if your running 7.1, you would need 9 channels (mains = 4 center = 1 rear surrounds = 2, side surrounds = 2)
    this is with saying that a 5 channel X 200 watt amp is more than adequate for the set up you listed in my opinion.
  • multifidus11
    edited June 2006
    the 7700 it 200wx7 and i was thinking along the same line as you in regards to using 4 channels (the main two and two of the 4 surrounds). this will work fine when the signal is coming from a two channel source such as a cd, where the preamp sends the same signal to all 7 channels. but won't i have a problem when i am watching a dvd encoded in 5.1 where the preamp splits the two surround signals into 4. at the point shouldn't i disconnect the surround cannel leads going to the rti12s and replace the jumpers. this would be way to much of a pain in the ****. i hope this makes sense. please advice if it does
  • multifidus11
    edited June 2006
    or do i just split the signal for the mains on the way from the preamp to 4 channels on the 7700. how would i do this if i upgraded to balanced cables?
