bi-wiring
fmax
what's the best way of biwiring my rt150's with a denon 3805 , was told to remove copper plate . do i just run double wire from same out-put is there some help out there
Post edited by fmax on
Yes, remove the jumper.
Yes, it's just a double run of wire. -
thank you very much . another option is bi-amping the speakers is this possible with this set up or will this mean i treat my self to a seperate amp . looking for a little more kick .
sorry this is all a little bit new to me . i was able to locate info with a search .
With bi-amping you would best be served with using an external Xover and bypassing the speakers Xovers.[
Explain please, in detail, why you believe this to be true.miner wrote:With bi-amping you would best be served with using an external Xover and bypassing the speakers Xovers. -
Frank Z wrote:Explain please, in detail, why you believe this to be true.
Ummm... phase inversions at crossover freqs? impedence stablility? Not turning amplifier power into heat?
Active bi amping is certainly better than passive biamp or biwiring. It's damn hard to do correctly, and probably not worth the trouble on most speakers, but it's hard to question that active biamping is ultimately better.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
http://sound.westhost.com/bi-amp.htm#common-questionFrank Z wrote:Explain please, in detail, why you believe this to be true.[ -
this is just a life long project for me i'm not in a rush ,but willing to learn . thanks for the input. well i have some wire that i bought used from a freind . good stuff in it's day . so i was told however times change . this is tributaries flat silver all i will do is the bi-wire for now pending cash flow . i also need to buy a set-up mic to see if that will help . the denon 3805 with the surround is nice for theater . with the music could use a little more kick . i think the rt 150 are a little power hungry , i like sound . once in a while you just want crank it . thanks fou your help .
