Caps?
hrdhtdvr
hrdhtdvr Posts: 103
edited June 2006 in Car Audio & Electronics
I get the impression on this board that people are against using capacitors. Why is this? :confused:
Alpine 9855 hu
Polk/Momo MMC 460 (Rear)
Polk/Momo MMC 6500 (Front)
Polk/Momo MM 2104 Sub
Amp: JL 500/5
Wires: Street Wires
Sat Radio: Sirius PNP
______________________
Home
Kenwood CD 425M 200 disc cd changer
Denon AVR-2801 reciever
Mitsubishi HS-U577
Toshiba -SD1700 DVD player
Klipsch Speakers
Center: RC-7
L&R:KLF-20
Surrounds:RS-3
Sub: KSW-15
Post edited by hrdhtdvr on
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited June 2006
    Alot of the time they are a band-aid solution to the problem. I also think that they are usually not needed. I had a system with over a kilowatt RMS of power and never used one.
    Doing the Big 3 first would be more beneficial.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • exalted512
    exalted512 Posts: 10,734
    edited June 2006
    basically what he said. 99% of the time caps are used improperly. The big 3 is about $100 cheaper and works about the same. Another battery(or just replacing the stock one) would be much more beneficial and you can get a red top for about $30 more than a 1 F cap
    -Cody
  • 1996blackmax
    edited June 2006
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    edited June 2006
    link doesnt work
    -Cody
  • 1996blackmax
    edited June 2006
    The website works on and off. Try it later....
    Actually the link just worked for me right now.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • hrdhtdvr
    hrdhtdvr Posts: 103
    edited June 2006
    Thank you. Interesting read.
    Alpine 9855 hu
    Amp: JL 500/5
    Wires: Street Wires
    Home
    Mitsubishi HS-U577
    Klipsch Speakers
    Center: RC-7
    L&R:KLF-20
    Surrounds:RS-3
    Sub: KSW-15
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited June 2006
    Edit -- Comment removed as it was incorrect.
    The Artist formerly known as PoweredByDodge
  • Vestax
    Vestax Posts: 31
    edited June 2006
    If you do decide to use a capacitor, make sure you find one with a very low ESR.
    Before thinking of using a cap, invest and research in the big 3, a very simple upgrade in wiring can help with your electrical system.
