Caps?
hrdhtdvr
I get the impression on this board that people are against using capacitors. Why is this?
Alpine 9855 hu
Polk/Momo MMC 460 (Rear)
Polk/Momo MMC 6500 (Front)
Polk/Momo MM 2104 Sub
Amp: JL 500/5
Wires: Street Wires
Sat Radio: Sirius PNP
______________________
Home
Kenwood CD 425M 200 disc cd changer
Denon AVR-2801 reciever
Mitsubishi HS-U577
Toshiba -SD1700 DVD player
Klipsch Speakers
Center: RC-7
L&R:KLF-20
Surrounds:RS-3
Sub: KSW-15
Amp: JL 500/5
Wires: Street Wires
Home
Mitsubishi HS-U577
Klipsch Speakers
Center: RC-7
L&R:KLF-20
Surrounds:RS-3
Sub: KSW-15
Post edited by hrdhtdvr on
Alot of the time they are a band-aid solution to the problem. I also think that they are usually not needed. I had a system with over a kilowatt RMS of power and never used one.
Doing the Big 3 first would be more beneficial.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
basically what he said. 99% of the time caps are used improperly. The big 3 is about $100 cheaper and works about the same. Another battery(or just replacing the stock one) would be much more beneficial and you can get a red top for about $30 more than a 1 F cap
Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
link doesnt work
The website works on and off. Try it later....
Actually the link just worked for me right now.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
Thank you. Interesting read.Alpine 9855 hu
Amp: JL 500/5
Wires: Street Wires
Home
Mitsubishi HS-U577
Klipsch Speakers
Center: RC-7
L&R:KLF-20
Surrounds:RS-3
Sub: KSW-15 -
Edit -- Comment removed as it was incorrect.The Artist formerly known as PoweredByDodge
If you do decide to use a capacitor, make sure you find one with a very low ESR.
Before thinking of using a cap, invest and research in the big 3, a very simple upgrade in wiring can help with your electrical system.
