Looking for sugestions on surround speakers for my 7.1 system
I am currently looking to set up a 7.1 channel system. What i have to work with is a pair of RT1000i, a CS400i center and a pair RT55i. My biggest question is what surrounds would be the best tember match for the older RT series speakers. I have been looking for the old F/X500i or F/X1000i surrounds but havent had any luck. Is there a newer current surround that will match exactly or as exact as possible with the RT series speakers i have. Also i was wandering what would be the best setup with my speakers. I am trying to decide if i should use the RT55i's or the RT1000i's as my rear center channels just throwin that out for opions as i will prob try both and see which sounds the best. mostly im lookin for a good surround speaker.
Post edited by carter04 on
Patience. 500's and 1000's will both pop up, just keep watching ebay / audiogon.
If you want to go ahead and get it setup and running, bag some 25's or 35's and rotate them to another rig when your multipole speakers show.
Cheers,
First, let's see if you'll benefit with a 7.1 setup. More speakers does not necessarily mean better sound.
What is your room size? How far is the seating position from the back wall?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
too many speakers in a confined area is bad.
I have some fx500's listed in our f/m for local sale.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Thanks for the input so far. I just finished my dedicated HT room its 14' wide and 18' long i havent arranged the sitting positions as of yet untill i get my speakers set up so i can place the sitting positions in the optimal positions.
Another forum member is selling some RT/FX speakers. Will suit your set up just fine...
http://www.polkaudio.com/forums/showthread.php?t=41706
Scott -
Skynut i would probabaly lean real heavy on buying your fx500i's but as i live on the othe side of the US in Tennessee the local pickup is not possible for me
Oh come on, aren't you up for a road trip?
I'll knock off $10.00 for gas.
Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
