Looking for sugestions on surround speakers for my 7.1 system
carter04
carter04 Posts: 3
edited June 2006 in Speakers
I am currently looking to set up a 7.1 channel system. What i have to work with is a pair of RT1000i, a CS400i center and a pair RT55i. My biggest question is what surrounds would be the best tember match for the older RT series speakers. I have been looking for the old F/X500i or F/X1000i surrounds but havent had any luck. Is there a newer current surround that will match exactly or as exact as possible with the RT series speakers i have. Also i was wandering what would be the best setup with my speakers. I am trying to decide if i should use the RT55i's or the RT1000i's as my rear center channels just throwin that out for opions as i will prob try both and see which sounds the best. mostly im lookin for a good surround speaker.
Post edited by carter04 on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2006
    Patience. 500's and 1000's will both pop up, just keep watching ebay / audiogon.
    If you want to go ahead and get it setup and running, bag some 25's or 35's and rotate them to another rig when your multipole speakers show.
    Cheers,
    Russ
  • Early B.
    Early B. Posts: 7,900
    edited June 2006
    First, let's see if you'll benefit with a 7.1 setup. More speakers does not necessarily mean better sound.
    What is your room size? How far is the seating position from the back wall?
    "God grooves with tubes."
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    too many speakers in a confined area is bad.
    I have some fx500's listed in our f/m for local sale.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • carter04
    carter04 Posts: 3
    edited June 2006
    Thanks for the input so far. I just finished my dedicated HT room its 14' wide and 18' long i havent arranged the sitting positions as of yet untill i get my speakers set up so i can place the sitting positions in the optimal positions.
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited June 2006
    Another forum member is selling some RT/FX speakers. Will suit your set up just fine...
    http://www.polkaudio.com/forums/showthread.php?t=41706
    Scott
  • carter04
    carter04 Posts: 3
    edited June 2006
    Skynut i would probabaly lean real heavy on buying your fx500i's but as i live on the othe side of the US in Tennessee the local pickup is not possible for me
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    Oh come on, aren't you up for a road trip?
    I'll knock off $10.00 for gas. :D
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
