recommendation for a relatively cheap remote preamp?
nadams
Hey all,
I got my system set up with the adcom amp and using the Luxman receiver as a preamp, but have one minor issue so far. That is, the Luxman does not have a remote control. So, I'd like to get some suggestions on a cheaper remote-controlled preamp. Anyone?
Thanks,
Noah
Thanks,
Noah
Ludicrous gibs!
Post edited by nadams on
oh shoot, my bad brotha. Didn't see that part. Check Ebay though for them...I've been "inches" from buying this for a couple years..Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
My buddy has a Nakamichi CA-5 pre that works great in his two channel rig. It can be found on ebay for about 100.00 or so. Sometimes cheaper. There is one that is ending in about an hour (looks a little worn though), and doesn't have a remote. If you have to have a remote, then the CA-7 is a solid pre.
Scott
edit: Guess I should of read your posting all the way through. Looks like you already have one w/ out a remote...... -
This should be interesting to hear what people recommend here as I am looking as well...
I am thinking of Rotel RC1070 or getting a RA1060, using the preamp section while using the amp for a zone 2....I have been using my X202ES cd player directly into my amp and want to use my modified Music Hall instead...
What about that TEAC integrated unit that had preouts?System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
