Opinion on new setup
ChrisinNY
ChrisinNY Posts: 7
edited June 2006 in Speakers
Hi all,
I've finally decided to go in for a surround sound system and I would like some opinions on the following setup:
TV - Samsung HL S6188W
Receiver - Yamaha RXV 2600
Speaker - Polk Surroundbar
Sub - Velodyne DPS12
The reason I've gone in for the Surroundbar is because of my room layout. It is around 14' x 18' with open walls on one side. The room is carpeted. The reason for the Yamaha, even though it looks like overkill, is twofold:
- I hope to be finishing my basement and moving the entire setup there, at which time I will probably go in for a full surround sound setup and the surroundbar will move to the bedroom
- the Yamaha can upconvert signals from my DVD player and switch to HDMI and it will allow me to expand in the future
Three alternate setups (keeping the same TV) to keep the budget down:
Receiver - Yamaha RXV 659
Sub - Velodyne DPS10
OR
Receiver - Denon 2805
OR
Receiver - one of the above
Front - RTi6
Center - CSi3
Surround - FXi3
I'm not sure if the last setup will really work given the layout of the room.
I would really appreciate some opinions. I'm totally inexperienced at this and I need to know if the entire setup is too much for the room size?
Post edited by ChrisinNY on
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    Never too much.
    I have never heard any of the products you mention.
    You can always turn the volume down but you never know when you will want it louder.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Mazeroth
    Mazeroth Posts: 1,585
    edited June 2006
    Definately the last option.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited June 2006
    Last option- The surround bar is cool but it can't totally replace seperate speakers in the correct locations.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • Shizelbs
    Shizelbs Posts: 7,433
    edited June 2006
    All would be cool in their own way, but the last option is your best bet.
  • Sami
    Sami Posts: 4,634
    edited June 2006
    I am pretty sure you can fit in the surrounds in a way it would still sound better than the surroundbar even without compromising the aesthetics. I once tried my surrounds behind the sitting location, on the floor facing up. Not optimal but not as bad as you would think either, and I would think there would be other ways to find some solution that sounds decent.
  • ChrisinNY
    ChrisinNY Posts: 7
    edited June 2006
    Thanks for the quick replies. I too prefer the last option but I'm kind of concerned with the positioning of the surround speakers. I have a large opening on one side of the seating location (opening into the kitchen). Is it ok to position the surround speakers about 7ft up? ie over the doorway? will they sound odd?
    Also, has anyone used the flat wires from decorp?
    http://www.decorp.com/product/audio.htm
    I've read all the arguments regarding good quality cables etc and I was wondering if anyone has tried these?
  • aaharvel
    aaharvel Posts: 4,489
    edited June 2006
    given your room concerns, I would go the Denon 2805, Surround Bar, DPS 10 and not look back.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Holydoc
    Holydoc Posts: 1,048
    edited June 2006
    Well it appears you have two objectives that you are trying to resolve:
    1) Temporary fix for this room
    2) Permanent setup for basement and bedroom
    The problem that you are going to run into is that the soundbar depends alot on reflection to get you the full surround effect. With you having one open wall, you might not get the effect you are looking for. Since the soundbar cannot be moved to negate this problem, you will be stuck with poor surround around.
    The problem with the RTi6's and FXi's is that it will allow you to get a much better surround effect but the RTi6's may be too small for your final basement setup.
    The advantages with getting the RTi's and FXi's is that the FXi's can be tranferred later to your basement as your surrounds without having to be replaced. This would give you the receiver, sub, and surrounds that you will not have to purchase in the future. The RTi6's could be transferred to your bedroom with cheap satelite speakers added later if you want surround sound.
    With this in mind, the RTi/FXi selection would give you better surround now and be the best cost effective in the future when you are building your final setup.
    Good luck.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • Holydoc
    edited June 2006
    The FXi's perform great at that height. Mine are set almost that high and because of the way they diffuse the sound, it works out great!
  • Sami
    Sami Posts: 4,634
    edited June 2006
    Absolutely, that's close to where they should be anyway.
    http://www.audioholics.com/techtips/setup/loudspeakers/hometheaterspeakerlayout.php
    "The main left and right surrounds should be to the respective sides of the listening area, above ear level if possible (ideally 2 feet or more)"
  • ChrisinNY
    ChrisinNY Posts: 7
    edited June 2006
    That's really good to hear! Now if I can figure out if the flat wire is any good, I can probably make a decision. I need to conceal the wires that will be running up the walls.
  • ChrisinNY
    ChrisinNY Posts: 7
    edited June 2006
    Thanks for the reply. Any reason you recommend the Denon over the Yamaha - other than the price?
  • Holydoc
    edited June 2006
    Since this is a temporary solution (the basement being the final goal), I would worry about getting the correct gauge and then aesthetics. As long as you get the correct gauge for the distance your speakers are at, you will be fine with flat wires.
    Here is a link to a nice table to help you decide on your gauge. (take the rest of the article with a grain of salt)
    http://www.roger-russell.com/wire/wire.htm#resistancehigh
    Now once you finish your basement and start setting up down there, I would resurface that wiring question since you will want everything perfect at that point.
    Good luck!
  • aaharvel
    edited June 2006
    nothing in particular. I'm simply not a fan of Yamaha at any pricepoint.
    But you may disagree. You should listen to both and see for yourself.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • ChrisinNY
    ChrisinNY Posts: 7
    edited June 2006
    thanks for all the replies. Just thought I'd give you an update - after all my research I had decided on the following setup:
    Front - RTi6
    Center - CSi3
    Sub - SVS 20-39 PCi (instead of the Velodyne DPS10)
    Surround - FXi3
    BUT it's not going to happen... :(:(:( my plans have been shot down and 'we' decided to go in for a samsung HTIB! :(
  • Willow
    Willow Posts: 11,218
    edited June 2006
    Are you sure you can't have "you" reconsider. You won't be happy and "you" will end up spending more down the line.
  • Mazeroth
    edited June 2006
    I'd rather listen to the television's speakers.
  • Willow
    edited June 2006
    or have it muted :o;)
  • Mike682
    Mike682 Posts: 2,074
    edited June 2006
    Welcome to the forum Chris.
    Where are you in NY?
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • ChrisinNY
    ChrisinNY Posts: 7
    edited June 2006
    I work in Westchester but live in CT. I've actually been lurking for more than a year on this forum and will probably go back to lurking. I find that most all of my questions get answered before I can post them!
    In defence of the decision, I must say that it's probably right given other circumstances but still... it was so close
  • Mike682
    edited June 2006
    I know how you feel..try doing a little at a time. What if you were to go a little lower on the receiver, something like a Yammy 5860 or 5960. Both have pre-outs for future upgrades and offer a nice feature set for the money
    Tell the other that HTIBs will cost more in the long run..
    Good luck, and hang around
    Mains: polk R30
    Center: polk CSi3
  • Willow
    edited June 2006
    Well why not wait till you save more $$$ or is it a size issue?
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2006
    Hi Chris & welcome.
    If it is a matter of money, & you have already waited this long, waiting & saving a little longer is not going to kill you.
  • ChrisinNY
    ChrisinNY Posts: 7
    edited June 2006
    believe it or not I was not the one driving the move to the whole home theatre thing. I watch barely 4 hours of tv a week - mostly news and in a good month I might watch 1 movie, I'm more of a book guy. It's just that whenever I decide to buy anything I really like to make it as perfect as I can afford. So... anyway, there's still time and things might change...
  • cfrizz
    edited June 2006
    Wow! That's a shocker!:D Now I really think that you should wait & save to get a nicer setup than HTIB! It's not too often that you get a woman who cares about a good audio system!
    Look at it this way, She'll be happy getting a system that she can be enthused about & the few times that you do sit down to watch TV or watch a movie, you'll be able to enjoy it as well knowing that you bought the very best sound for the money that you've spent!:)
  • Willow
    edited June 2006
    ChrisinNY wrote:
    I'm more of a book guy. ...
    lots of books are turned into movies....;)
