Opinion on new setup
Hi all,
I've finally decided to go in for a surround sound system and I would like some opinions on the following setup:
TV - Samsung HL S6188W
Receiver - Yamaha RXV 2600
Speaker - Polk Surroundbar
Sub - Velodyne DPS12
The reason I've gone in for the Surroundbar is because of my room layout. It is around 14' x 18' with open walls on one side. The room is carpeted. The reason for the Yamaha, even though it looks like overkill, is twofold:
- I hope to be finishing my basement and moving the entire setup there, at which time I will probably go in for a full surround sound setup and the surroundbar will move to the bedroom
- the Yamaha can upconvert signals from my DVD player and switch to HDMI and it will allow me to expand in the future
Three alternate setups (keeping the same TV) to keep the budget down:
Receiver - Yamaha RXV 659
Sub - Velodyne DPS10
OR
Receiver - Denon 2805
OR
Receiver - one of the above
Front - RTi6
Center - CSi3
Surround - FXi3
I'm not sure if the last setup will really work given the layout of the room.
I would really appreciate some opinions. I'm totally inexperienced at this and I need to know if the entire setup is too much for the room size?
OR
OR
Front - RTi6
Center - CSi3
Surround - FXi3
Post edited by ChrisinNY on
Never too much.
I have never heard any of the products you mention.
You can always turn the volume down but you never know when you will want it louder.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Definately the last option.
Last option- The surround bar is cool but it can't totally replace seperate speakers in the correct locations.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
All would be cool in their own way, but the last option is your best bet.
I am pretty sure you can fit in the surrounds in a way it would still sound better than the surroundbar even without compromising the aesthetics. I once tried my surrounds behind the sitting location, on the floor facing up. Not optimal but not as bad as you would think either, and I would think there would be other ways to find some solution that sounds decent.
Thanks for the quick replies. I too prefer the last option but I'm kind of concerned with the positioning of the surround speakers. I have a large opening on one side of the seating location (opening into the kitchen). Is it ok to position the surround speakers about 7ft up? ie over the doorway? will they sound odd?
Also, has anyone used the flat wires from decorp?
http://www.decorp.com/product/audio.htm
I've read all the arguments regarding good quality cables etc and I was wondering if anyone has tried these? -
given your room concerns, I would go the Denon 2805, Surround Bar, DPS 10 and not look back.
Well it appears you have two objectives that you are trying to resolve:
1) Temporary fix for this room
2) Permanent setup for basement and bedroom
The problem that you are going to run into is that the soundbar depends alot on reflection to get you the full surround effect. With you having one open wall, you might not get the effect you are looking for. Since the soundbar cannot be moved to negate this problem, you will be stuck with poor surround around.
The problem with the RTi6's and FXi's is that it will allow you to get a much better surround effect but the RTi6's may be too small for your final basement setup.
The advantages with getting the RTi's and FXi's is that the FXi's can be tranferred later to your basement as your surrounds without having to be replaced. This would give you the receiver, sub, and surrounds that you will not have to purchase in the future. The RTi6's could be transferred to your bedroom with cheap satelite speakers added later if you want surround sound.
With this in mind, the RTi/FXi selection would give you better surround now and be the best cost effective in the future when you are building your final setup.
Good luck.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
ChrisinNY wrote:Thanks for the quick replies. I too prefer the last option but I'm kind of concerned with the positioning of the surround speakers. I have a large opening on one side of the seating location (opening into the kitchen). Is it ok to position the surround speakers about 7ft up? ie over the doorway? will they sound odd?
The FXi's perform great at that height. Mine are set almost that high and because of the way they diffuse the sound, it works out great!Holydoc (Home Theatre Lover)
ChrisinNY wrote:Is it ok to position the surround speakers about 7ft up? ie over the doorway?
http://www.audioholics.com/techtips/setup/loudspeakers/hometheaterspeakerlayout.php
"The main left and right surrounds should be to the respective sides of the listening area, above ear level if possible (ideally 2 feet or more)" -
Holydoc wrote:The FXi's perform great at that height. Mine are set almost that high and because of the way they diffuse the sound, it works out great!
That's really good to hear! Now if I can figure out if the flat wire is any good, I can probably make a decision. I need to conceal the wires that will be running up the walls. -
aaharvel wrote:given your room concerns, I would go the Denon 2805, Surround Bar, DPS 10 and not look back.
Thanks for the reply. Any reason you recommend the Denon over the Yamaha - other than the price? -
ChrisinNY wrote:That's really good to hear! Now if I can figure out if the flat wire is any good, I can probably make a decision. I need to conceal the wires that will be running up the walls.
Since this is a temporary solution (the basement being the final goal), I would worry about getting the correct gauge and then aesthetics. As long as you get the correct gauge for the distance your speakers are at, you will be fine with flat wires.
Here is a link to a nice table to help you decide on your gauge. (take the rest of the article with a grain of salt)
http://www.roger-russell.com/wire/wire.htm#resistancehigh
Now once you finish your basement and start setting up down there, I would resurface that wiring question since you will want everything perfect at that point.
Good luck!Holydoc (Home Theatre Lover)
ChrisinNY wrote:Thanks for the reply. Any reason you recommend the Denon over the Yamaha - other than the price?
nothing in particular. I'm simply not a fan of Yamaha at any pricepoint.
But you may disagree. You should listen to both and see for yourself. -
thanks for all the replies. Just thought I'd give you an update - after all my research I had decided on the following setup:
Front - RTi6
Center - CSi3
Sub - SVS 20-39 PCi (instead of the Velodyne DPS10)
Surround - FXi3
BUT it's not going to happen... my plans have been shot down and 'we' decided to go in for a samsung HTIB! -
Are you sure you can't have "you" reconsider. You won't be happy and "you" will end up spending more down the line.
I'd rather listen to the television's speakers.
Mazeroth wrote:I'd rather listen to the television's speakers.
or have it muted -
Welcome to the forum Chris.
Where are you in NY?Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Mike682 wrote:Welcome to the forum Chris.
I work in Westchester but live in CT. I've actually been lurking for more than a year on this forum and will probably go back to lurking. I find that most all of my questions get answered before I can post them!
In defence of the decision, I must say that it's probably right given other circumstances but still... it was so close -
ChrisinNY wrote:I work in Westchester but live in CT. I've actually been lurking for more than a year on this forum and will probably go back to lurking. I find that most all of my questions get answered before I can post them!
I know how you feel..try doing a little at a time. What if you were to go a little lower on the receiver, something like a Yammy 5860 or 5960. Both have pre-outs for future upgrades and offer a nice feature set for the money
Tell the other that HTIBs will cost more in the long run..
Good luck, and hang aroundReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
ChrisinNY wrote:In defence of the decision, I must say that it's probably right given other circumstances but still... it was so close
Well why not wait till you save more $$$ or is it a size issue? -
Hi Chris & welcome.
If it is a matter of money, & you have already waited this long, waiting & saving a little longer is not going to kill you.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Willow wrote:Well why not wait till you save more $$$ or is it a size issue?
believe it or not I was not the one driving the move to the whole home theatre thing. I watch barely 4 hours of tv a week - mostly news and in a good month I might watch 1 movie, I'm more of a book guy. It's just that whenever I decide to buy anything I really like to make it as perfect as I can afford. So... anyway, there's still time and things might change... -
Wow! That's a shocker!:D Now I really think that you should wait & save to get a nicer setup than HTIB! It's not too often that you get a woman who cares about a good audio system!
Look at it this way, She'll be happy getting a system that she can be enthused about & the few times that you do sit down to watch TV or watch a movie, you'll be able to enjoy it as well knowing that you bought the very best sound for the money that you've spent!:)Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
ChrisinNY wrote:I'm more of a book guy. ...
lots of books are turned into movies....;)
