A'goin' Mattress shopping.... HELP!!
zombie boy 2000
zombie boy 2000 Posts: 6,641
edited April 2024 in Clubhouse Archives
So after weeks of being entirely overwhelmed everytime we enter a mattress store, the wife and I are putting the clamp down tonight and making a purchase. We've had enough of our current set-up, and we need something now. So knowing possibly less than when we first started looking, I need advice, inuput, info, etc., as I am at a complete loss.:o
First off, we know that we don't want something too firm, but nothing too incredibly soft. No need for memory foam or anything the astronauts sleep on. Really it's the prices that have me baffled. I really haven't been able to tell a difference between some $450 mattressess and $2500 mattresses. Plus, as we have a platform bed, we won't be needing a box spring.
The key here is.... best bang for the buck (fire at will, gentlemen:D ). If it's cheap and comfy, then we're talking.
Thanks in advance for your input
Jason
  • Demiurge
    Demiurge Posts: 10,874
    edited June 2006
    Try a Sleepcomfort. They're amazing.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2006
    I'm in the same boat. Girlfriend is bugging me to get a more comfortable mattress which means I will likely be buying a new mattress before I buy any considerable audio gear to keep balance of the world in order.
    Mattress Giant (I think) was having a 50% off sale. They had a couple $2000 mattresses for half price. May start there, if you have an MG by you.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2006
    Just make sure whatever you buy is comfortable and has a good warranty, with emphasis on the good warranty.
    Most will come with a long warranty period, but you need to make sure that warranty is comprehensive. If you spills something on the matress, does that void the warranty? if you're looking at a king size, does the warranty cover any sagging in the middle that will inevitably happen. A warranty is worth every extra penny if you get a bumper to bumper, no questions asked type deal - unfortunately those come with higher price tags.
    Did I mention that the warranty is important?
    Also, if a place isn't going to let you return the mattress after trying it for a couple of weeks - don't do business with them. it's going to feel different after sleeping on it a few nights than it does in the store, so make sure you have the option or returning it.
    Oh, andd you might want to make sure whatever mattress you buy has a really good warranty too...
  • Demiurge
    edited June 2006
    Sleep Comfort comes with a 20 year warranty. They'll come in and set it up and take out your old one. Best. Bed. Ever.
    No, I don't own stock. ;)
  • joeparaski
    joeparaski Posts: 1,865
    edited June 2006
    I went throught the same thing last year. Whatever you choose, make it clear with the salesman that you want the option of exchanging it for another one. We chose one we thought we'd like, but after a few nights it was apparent we wouldn't want to keep it. We used the exchange policy and got a different one that we are happier with.
    If you have back problems your needs for a mattress will be different. So ask questions concerning that.
    Lie on several different mattresses at their showrooms for a few minutes, (don't be shy) lie in the position you normally sleep in. Lie on one after the other as if you are auditioning speakers in an A-B-C-D comparison. You'll quickly weed out the ones that are less comfortable and then it will come down 2 or 3 choices. At that point it may become an issue of price, because invariably, the priciest one sometimes ends up being the most comfortable.
    The first one we chose cost $1100 but we then exchanged for the $1500 model. We ended up with the SERTA "Perfect Sleeper" model.
    The golden rule is to make absolutely clear that you are allowed to exchange it if you don't like it....I think they give you a few weeks to a month to exchange it.
    Good luck and good sleeping.
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • bobman1235
    bobman1235 Posts: 10,822
    edited June 2006
    My dad bought a SelectComfort (which I THINK is what Demi was referring to?), and hasn't looked back since. They're a LITTLE more expensive than a traditional, but they come with a warranty, and they come and set it up for you at your house. And basically it can be a soft mattress, a firm mattress, BOTH if you and your wife don't have th esame "taste"... it's all things to all people :)
    I'd get one if I could afford it....
  • halo
    halo Posts: 5,618
    edited June 2006
    Avoid Serta "Perfect Sleeper" at all costs. We bought a new mattress just over a year ago and, while it was nice when it was new, I'm about ready to toss it in the garbage.
    One mattress I had, and really liked, was a Simmons Beauty Rest. No fancy pillotop or anything - just a comfortable mattress. All I did was sit down on the thing in the store. It felt really comfortable so I bought it. Lasted a long time too. Don't ask me why I didn't get another beauty rest. The first time it was my decision to buy it - the Serta was a joint decision (WAF).
    You can't tell anything by laying on a mattress in the store unless you plan on taking a nap there.
    I've heard good things about the Select Comfort mattress but that may be more than you want to spend.
    Good luck.
    Make sure the place you buy it from has a return / exchange policy so that you can get something else if you really don't like it.
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
  • zombie boy 2000
    edited June 2006
    Thank you all for your suggestions so far....
    This is invaluable:)
  • Willow
    Willow Posts: 11,244
    edited June 2006
    I never thought going up in price made big difference. I would buy 400-600 for both matt & boxspring. Then after feeling the springs in my ribs, my now wife, gf at the time said "since we are moving in together it's time" We looked around...and around...and around... We fond one that was amazing for us, it's by obusform as I have ongoing back issues. Ordered that puppy matt & boxspring, 3500$ later....The best nights sleep I have ever had. Again, think of it like audio, if you like the way it feels then buy it. As Joe said buy from a place that has a trial period, ours is 90 nights.
  • MattN03
    MattN03 Posts: 558
    edited June 2006
    My wife & I bought a Select Comfort king size matress last year and absolutely love it. It's the most comfortable matress I've ever slept on, and we can change each side independently so we're both happy! Their not cheap, but worth the time to check out atleast. Here is their website. We have the 7000 series.
  • joeparaski
    edited June 2006
    Good luck.
    Hmmm....interesting...I can't say that's been our experience. So far, our Perfect Sleeper is, well, perfect.
    Laying on the mattresses in the showroom immediately eliminated many from the final choices, so in my opinion there is some value in lying on the showroom models.
  • halo
    halo Posts: 5,618
    edited June 2006
    Not trying to diss you joe :o Just relaying my experiences with the mattress shopping ordeal :) Glad to hear the Serta is working for you :) If I could afford a new mattress I would seriously consider the Select Comfort.
  • danger boy
    danger boy Posts: 15,722
    edited June 2006
    mattresses are pricey for the good ones.. but they are worth it..
    i'm looking to buy a new one this winter probably myself.. i can't seem to get out of my mind how comfy those pillow top ones are. I've demoed them at a few stores in the past few months. Man, i could really get used to a nice thick pillow top mattress.
    Here is an idea.. where i live there about three places in town that build their own mattresses.. and at discount prices. Don't dismiss them at all though.. they supply most of the bed for the higher end hotels here in town. so they're not gut rot mattresses at all . Plus buying from them at the warehouse prices they offer... could save you some bucks. Worth checking out.
    *i'm listening to FM radio right now. guess what? There is a mattress outlet commercial spot on the radio. Waaaaaaaaaaa!
    Vera Wang mattress????? That's what they're pushing on the radio. Hmmmmm?
    PolkFest 2012, who's going>?
  • zombie boy 2000
    edited June 2006
    I'm with you DB...
    the problem is they're allcomfortable when I "demo" 'em -- which doesn't speak highly of our current set-up
    Come to think of it, just about anything is going to offer a vast improvement.
    Anyway, I'd rather just sleep on the floor if it meant I could swing a couple of audio upgrades:D just kidding....
    no I'm not
    anyway,
    Select Comfort
    Perfect Sleeper
    Simmons Beautyrest
    still trying to keep it affordable though....
  • Willow
    edited June 2006
    Speaking of pillow tops, ours is on both sides, so when we flip it it's the same. Now keep in mind that some of yuor older sheets might not fit the single or double pillow tops..we had to go out and buy new fitted sheets.
  • bvette94
    bvette94 Posts: 356
    edited June 2006
    check out your local sams club if there is one in your area. prices are pretty good and no sales man pressure.
  • zombie boy 2000
    edited June 2006
    effin' hilarious:D
    the stars must be aligning..
  • zombie boy 2000
    edited June 2006
    can you get mattresses from Sam's Club if you're not a member? We have one around here, but I've never set foot in it... so I don't know how it works.
  • Demiurge
    edited June 2006
    If you know someone who is a member you can go in with them.
  • zombie boy 2000
    edited June 2006
    ....and besides, doesn't Sam's Club just sell tank-sized jars of pickles?
    didn't know they were in the bedding industry:D
  • Demiurge
    edited June 2006
    They're into electronics, dvds, and arsewipe, and so on. :p
  • BIZILL
    BIZILL Posts: 5,432
    edited June 2006
    get whatever feels best with a long warranty. if one costs more than another and you like it best, but it's like $500 more, think about $500 stretched out over the life of the mattress (10 or so years) and it pays to pay extra. i went cheap and wish i had not.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • brettw22
    brettw22 Posts: 7,623
    edited June 2006
    This is exactly what I did when I bought my bed last year. When I found a mattress that I fell asleep on in the middle of the store after being on the bed for 10 minutes or so, I knew I was gonna buy it. I think I was out for about 20-30 minutes actually. I have to check when I get home as to what exactly I bought and will let you know.
    Many of the pillowtops nowadays are just on one side eliminating the need to flip/turn/rotate for an even wear. Mine's just on top and I don't ever have to spin it at all.
    One thing to keep in mind is that you HAVE to ask specifically if the mattres warranty if voided if you don't use their box spring. I've heard stories from people that they didn't use the box and the manufacturer basically incinuated that they didn't have proper support for their mattress and they had no claim. BIG mistake that can cost in the thousands. Whatever you do, don't tell them you're putting it on a platform......take the box springs home and store them somewhere, because should a claim ever need to arise, you better have those things around.
  • Willow
    edited June 2006
    Even when we didn't have pillow top we still flipped it. Your torso weighs more than your legs and your spouse/GF/BF/husband/lover/mistress might weigh more or less than you. By flipping and rotating , it moves the usual used spots somehere else.
  • zombie boy 2000
    edited June 2006
    Brett -
    Thanks for the head's up on the box spring/warranty connection... We were probalby going to try to save some money by not purchasing the box spring. Now, I'm not too sure...
    Willow -
    I knew to flip and rotate it every so often, but had never really put much thought into "why". Now I know....
    and btw, my fat mistress boyfriend lover wife partner thanks all of you for your advise thus far:D
  • Willow
    edited June 2006
    I was trying to cover all bases ;)
  • ohskigod
    ohskigod Posts: 6,505
    edited June 2006
    I'll vouch for King air, pillow top. sweet
    all I can say is, dont skimp, youll pay in the long run
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Gaara
    Gaara Posts: 2,415
    edited June 2006
    Moved...see page two. I had to go work out and when I re-read what I wrote I realized it wasn't nearly as much as I was wanted to say. Its in two parts because I exceeded the 10,000 character limit. Opps.
    Jared
  • AsSiMiLaTeD
    edited June 2006
    ^^ I believe that's the most informative and comprehensive post on any topic I've ever read...
  • Demiurge
    edited June 2006
    Mattress Master
