The Sopranos in 5.1
ted538
I was wondering if someone can help me out.I noticed that The Sopranos is available in 5.1 format where available.I own the Denon 1802.How do I set it up to get the 5.1 DD?..I appreciate your help..I use the 5 channel stereo set up on my receiver and the sound is soooo low..I really want to hear it in 5.1.
But on Yamahamers, when there is a 5.1 signal and the "effect" setting is on,
it automatically does the DD thang.
Denonophiles help him out.
-luc -
You have to have digital cable, Direct TV or Dish network. 5.1 is only available with a digital signal.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I have digital cable..what do I need to do?
Does your cable box offer a digital out?
If so use the digital out connection to your receiver, you may want to check the audio set-up on the cable box and see if you have to tell it to use the digital out. This should do it.Dodd - Battery Preamp
You nailed it hoosier. If the cable box has only analogue outs then no DD possible. In this case Pro Logic is the only choice for surround.***WAREMTAE***
You can try to request a box with this feature. Allot of cable companies have them available, but do not include it on all of their boxes to save $$$$$$. AT&T is one of them."The only way to get rid of a temptation is to yield to it."
I have a Denon as well and am using an optical cable out of my sattellite box..the Denon automatically picks up the DOlby signal
thanks for the help guys..I`ll give it a try next Sunday..god I would love to bang Meadow..
