The Sopranos in 5.1
ted538
ted538 Posts: 63
I was wondering if someone can help me out.I noticed that The Sopranos is available in 5.1 format where available.I own the Denon 1802.How do I set it up to get the 5.1 DD?..I appreciate your help..I use the 5 channel stereo set up on my receiver and the sound is soooo low..I really want to hear it in 5.1.
  • trubluluc
    trubluluc Posts: 2,067
    edited October 2002
    But on Yamahamers, when there is a 5.1 signal and the "effect" setting is on,
    it automatically does the DD thang.
    Denonophiles help him out.
    -luc
  • hoosier21
    hoosier21 Posts: 4,418
    edited October 2002
    You have to have digital cable, Direct TV or Dish network. 5.1 is only available with a digital signal.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • ted538
    ted538 Posts: 63
    edited October 2002
    I have digital cable..what do I need to do?
  • hoosier21
    edited October 2002
    Does your cable box offer a digital out?
    If so use the digital out connection to your receiver, you may want to check the audio set-up on the cable box and see if you have to tell it to use the digital out. This should do it.
  • HBombToo
    HBombToo Posts: 5,256
    edited October 2002
    You nailed it hoosier. If the cable box has only analogue outs then no DD possible. In this case Pro Logic is the only choice for surround.
    ***WAREMTAE***
  • jrausch
    jrausch Posts: 510
    edited October 2002
    You can try to request a box with this feature. Allot of cable companies have them available, but do not include it on all of their boxes to save $$$$$$. AT&T is one of them.
    "The only way to get rid of a temptation is to yield to it."
  • Billm57
    Billm57 Posts: 689
    edited October 2002
    I have a Denon as well and am using an optical cable out of my sattellite box..the Denon automatically picks up the DOlby signal
  • ted538
    ted538 Posts: 63
    edited October 2002
    thanks for the help guys..I`ll give it a try next Sunday..god I would love to bang Meadow..
