Crossover help
eatthatmonkey20
eatthatmonkey20 Posts: 1
edited June 2006 in DIY, Mods & Tweaks
I'm building a pair of home speakers with 4 Polk MM2124 subs and 2 pairs of Polk MM6 components that came from my old car which was total from hail damage. Each speaker will have 2 subs, 2 mids, and 2 tweeters, all 4 ohms ran in series to produce an 8 ohm load. What kind of crossover should I use to split the signal to my subs from the components? The MM6's came with crossovers so I think I just need a 2 way crossover at 80 htz. My concern is that I may need something that can adjust the power delivered to the subs or mids in case the volume levels don't match up. Any ideas?:confused:
  • phoneisbusy
    phoneisbusy Posts: 867
    edited June 2006
    Welcome.
    You may want to consider an active crossover like the Paradigm X-30 Crossover / Controller. If you have a home theatre receiver, it should also handle that. A passive crossover would probably require quite a big inductor and that can add up quickly.
    If you use a plate amp for your subs, they may also come with speaker level crossovers.
    good luck
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • Mazeroth
    Mazeroth Posts: 1,585
    edited June 2006
    Sell all that car audio stuff and buy drivers designed for home use. You'll have a rough time dialing in car speakers to sound right in the home environment, due to them being designed for pretty much an infinite baffle.
    I'd also build a design that someone has really researched and put through the ringer. There are a lot of unbelievable designs in the "sticky" threads on this board. Most of these designs will outperform speakers costing 5-10x their cost to build:
    http://www.htguide.com/forum/forumdisplay.php4?f=6
