Rm 6800 Sub Wiring Help
SANTE
SANTE Posts: 1
Hi all,
I'm newbie with my home theather and I have some questions to you. :confused:
I have purchased a RM6800 Home Theater spaeakers running with an A/V Receiver Onkyo TX-SR 603. My question is how you connect the subwofer pre out from the Onkyo (single RCA exit) to the subwofer Line In (Two RCA connections L,R) ?
It is better doing this connection or do you prefer using polk hook up meyhod (does not connect the subwofer to the sub pre out form Onkyo). ?
Thanks for your help :)
Juan Luis
Barcelona (Spain)
Post edited by SANTE on
  • MLZ
    MLZ Posts: 214
    edited June 2006
    I have the same setup, tried both setups and prefer to use the 603's sub out to the sub. The difference was most noticible for movies LFE. Do a search of the forum and you will see several threads over the past six months on how to hook up the sub.
