Running 8 Speakers of a 4 channel amp?
DayUSeX
DayUSeX Posts: 4
edited June 2006 in Car Audio & Electronics
So i want to throw 4 more speakers in my sytem and was wondering if i could do this with my current 4 channel amp (carbon 4 channel). If i can do this, how would i go about wiring this, or would I be better off just buying another amp? THanks
Post edited by DayUSeX on
  • exalted512
    exalted512 Posts: 10,734
    edited June 2006
    put 2 speakers on each channel, + to +, - to -
    -Cody
  • DayUSeX
    DayUSeX Posts: 4
    edited June 2006
    SO would i have to split or splce into the line? or could i just run two lines form the amp, also how woudl sound quality be,? Woult it be just as good as running two amps, or should i really get two amps?
  • bknauss
    bknauss Posts: 1,441
    edited June 2006
    Two amps is probably your best bet.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2006
    Just my $.02 but unless those are subs, there is really no need for 8 speakers.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited June 2006
    Link with a Maxima with a good amount of speakers up front...
    http://www.turboegt.com/Cars/Maxima/Audio/Version%203.0/Version%203.0%20Main.htm
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • DayUSeX
    DayUSeX Posts: 4
    edited June 2006
    thing is i want my system louder, i want it to churn peoples souls when they hear my system, so that is why i wnat 8 speakers.
  • exalted512
    edited June 2006
    i dont understand what you mean by splice?
    SQ wont be as good as 2 seperate amps because youre running the amp at a lower impedance. Whether you can actually tell the differenece is different from person to person.
    -Cody
  • MacLeod
    edited June 2006
    Adding 4 more speakers wont make it much more than 3 db louder.
    That 400.4 will have enough power to easily damage your hearing. You should look into adding some subs if youre wanting more volume. Get a couple Carbon 500.1's and a couple MM2124DVC's and thatll do 10 times more for being louder than adding 4 more speakers.
  • exalted512
    edited June 2006
    3 dB for highs is a LOT louder than 3 dB in subs...
    -Cody
