Running 8 Speakers of a 4 channel amp?
DayUSeX
So i want to throw 4 more speakers in my sytem and was wondering if i could do this with my current 4 channel amp (carbon 4 channel). If i can do this, how would i go about wiring this, or would I be better off just buying another amp? THanks
Post edited by DayUSeX on
put 2 speakers on each channel, + to +, - to -
SO would i have to split or splce into the line? or could i just run two lines form the amp, also how woudl sound quality be,? Woult it be just as good as running two amps, or should i really get two amps?
Two amps is probably your best bet.Brian Knauss
ex-Electrical Engineer for Polk -
Just my $.02 but unless those are subs, there is really no need for 8 speakers.polkaudio sound quality competitor since 2005
Link with a Maxima with a good amount of speakers up front...
http://www.turboegt.com/Cars/Maxima/Audio/Version%203.0/Version%203.0%20Main.htmAlpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
thing is i want my system louder, i want it to churn peoples souls when they hear my system, so that is why i wnat 8 speakers.
i dont understand what you mean by splice?
SQ wont be as good as 2 seperate amps because youre running the amp at a lower impedance. Whether you can actually tell the differenece is different from person to person.
DayUSeX wrote:thing is i want my system louder, i want it to churn peoples souls when they hear my system, so that is why i wnat 8 speakers.
Adding 4 more speakers wont make it much more than 3 db louder.
That 400.4 will have enough power to easily damage your hearing. You should look into adding some subs if youre wanting more volume. Get a couple Carbon 500.1's and a couple MM2124DVC's and thatll do 10 times more for being louder than adding 4 more speakers.polkaudio sound quality competitor since 2005
3 dB for highs is a LOT louder than 3 dB in subs...
