Balanced and Unbalanced
Pepi28
Pepi28 Posts: 248
Hi Polkees,
Can anyone tell me what the difference between balanced and unbalanced inputs on an amplifier is and what it means. I am planning on buying a couple of 2 channel and 3 channel amps from Rotel and keep seeing these inputs. Any help would be greatly appreciated. Also I am going to use the preouts on my Sony ES receiver until I get a pre/pro next year hopefully, will this receiver work ok with the Rotels when I get them. Thanks PEPI
58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub
Post edited by Pepi28 on
    F1nut Posts: 51,757
    edited June 2006
    Rotel has balanced outs???
    Well, if they do their amps aren't truely balanced, so don't worry about it.
  • Sthrndream
    Sthrndream Posts: 70
    edited June 2006
    Balanced is a 3 pin XLR connector that you use in lieu of an RCA jack. Balanced connectors (XLR) are superior in noise rejection. For example, If you had a radio station tower nearby and you heard the radio station through your speakers while playing other sources (i.e. tuntable, TV, etc) you would want to use XLR balanced connectors.
    This situation happened to me and I believe its the only way to go. If you have a pronounced hiss in your sysgtem, balanced connectors generally would eliminate this as well.
    Hope this helps.
  • janmike
    janmike Posts: 6,146
    edited June 2006
    I owned a 1080 and it had both balanced and unbalanced. The 1095 does as well and check out the Rotel web site for info on all their amps. Are they truly balanced? Good question.
    Rotel
    Michael ;)
    NORTH of 60°
    F1nut Posts: 51,757
    edited June 2006
    Thank you Michael, I really didn't know.
