Ei Elite 6DJ8EG
W WALDECKER
i just got a quad of these today, they have a A frame construction similar to some of the earlier NOS Western European 6DJ8s and they have two ridges at the top of the bottle which was found on Amperex , Siemens and Telefunken tubes. i just rolled them into the BAT VK 3i and they sounded pretty nice cold right out of the box. i am waiting for a replacement midbass driver for my Loreleis so i am using Studio 100 v3s till i can get my babies up and running again. they sound good thru the Reference Studio Paradigms. i will let the Ei Elite 6DJ8EGs burn in for a few days and give my impressions on them. i just got off of the phone with Klaus Bunge at Odyssey Audio and he said i should get my replacement Scanspeak 8545 by friday. by then the tubes shoud be settled in nicely. thanks....WCW III
Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
Post edited by W WALDECKER on
these are the gold pins , correct ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
beardog03 wrote:these are the gold pins , correct ?Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers. -
cool..!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
What are you going to compare them to? Don't you have some 7308?
Gold pins don't matter much, unless you've got gold sockets also. Dissimilar metals making contact can actually accelerate corrosion in some cases.
Thanks RCG Esq. IVCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Very cool. I'm very interested to hear your opinion on this tube.
I have a pair labeled "Jolida" (thanks Noel!) that I'm going to try on my GTA pre-amp when it comes back.
The small signal tubes from Ei have a very bad rep. Usually noise and microphonic. Looks like you got your quad from a good dealer that tests them. They'll probably need about 50hrs of break in before they blossom.
Enjoy your tubes, bro. -
RuSsMaN wrote:What are you going to compare them to? Don't you have some 7308?
Thanks RCG Esq. IVRogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
That all sounds complicated but enjoy:DSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
The Ei Elite 6DJ8EGs have been running in my system for around 60 hours.i will throw out a few observations based on using these twin triodes in my particular system. Pitch black background. bass response is very good.the midrange sounds terrific. there is a little Hi Fi sparkle on the top but not even close to the point of being bright. these tubes have outperformed both my very expensive Amperex 7308s and the factory supplied Sovtecs when used in my Balanced Audio Technology VK 3i Linestage.for $8.95 a pop i would recommend for anyone using a preamp with 6DJ8/ 6922/7308 tubes to give them a try. thanks....WCW IIIRogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
William, where did you purchase them, I can't find any online stores that have them in stockJC approves....he told me so. (F-1 nut)
I've tried the EI Elite golds in my Dodd ELP- They sound okay there, but they're not my favorites. They're real mellow sounding to me- which works well on some music- but there's nothing about their performance that really stands out, IMO. The JAN 6922 Phillips or the JJ's sound better in the ELP in my rig, and both seem to have better bass than the EI's.
You can get them here: http://www.boiaudioworks.com/index.php?cPath=22&osCsid=ea5322f63fe7167a2dcd55f2ebde97b4
I've bought tubes from them before and the service has been good. They've also got the same tube without the gold plated pins, which as RuSsMaN mentioned, might be as good or better.
Jason -
I just went and hooked the `ol Dodd back up and decided to put the Ei`s in, and though I didn`t realize it, the are gold pins....go figure !
(6DJ8EG)
matched;
gm triode 1....90....on both tubes
gm triode 2....85....on both tubes
I really like these tubes, but they do need a few more hours on themCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
jcaut wrote:I've tried the EI Elite golds in my Dodd ELP- They sound okay there, but they're not my favorites. They're real mellow sounding to me- which works well on some music- but there's nothing about their performance that really stands out, IMO. The JAN 6922 Phillips or the JJ's sound better in the ELP in my rig, and both seem to have better bass than the EI's.
JasonRogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
george daniel wrote:William, where did you purchase them, I can't find any online stores that have them in stockRogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
