Urgent dlp Help
hexumjunkie
hexumjunkie Posts: 191
edited June 2006 in Electronics
Have dlp TV in my bar and everytiome i turn it on it takes like 20 minutes before the red comes on.....bad connection, bad cable box?, bad wires.....
Post edited by hexumjunkie on
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    I just bought mine and it takes awhile for the picture to warm up.
    It is like an old tube set.
    Other than that I can't help.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Willow
    Willow Posts: 11,233
    edited May 2006
    are your cables connected properly ?
  • hexumjunkie
    edited June 2006
    connected via hdmi i get no reds when tv forst comes on the red and green lines scan on the screen if i look real close takes about 5 minutes for the reds to come in
  • hexumjunkie
    edited June 2006
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    Now I have had mine for a little while I noticed it takes a while to warm up.
    Maybe it is just normal?
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
