Urgent dlp Help
hexumjunkie
Have dlp TV in my bar and everytiome i turn it on it takes like 20 minutes before the red comes on.....bad connection, bad cable box?, bad wires.....
Post edited by hexumjunkie on
I just bought mine and it takes awhile for the picture to warm up.
It is like an old tube set.
Other than that I can't help.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
are your cables connected properly ?
connected via hdmi i get no reds when tv forst comes on the red and green lines scan on the screen if i look real close takes about 5 minutes for the reds to come in
bump
Now I have had mine for a little while I noticed it takes a while to warm up.
Maybe it is just normal?Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
