Carver Hologram with SDA speakers
riglehart
riglehart Posts: 276
edited June 2006 in Vintage Speakers
I'm looking at used preamps. The "hologram" feature of the old Carvers claims to minimize the audio crosstalk the listener perceives.
See...
http://www.audio-ideas.com/interview/carver.html
Anyone know how they sound with SDAs.
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
  • SDA SRS 1.2
    SDA SRS 1.2 Posts: 255
    edited May 2006
    I have the sonic hologram on my C-16 preamp. I never really thought it did much although Carver claimed it was compatible with the SDA. It seemed as a bit of overkill with SDA.
    Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
    Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
    Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD! :) )
    F1nut Posts: 51,813
    edited May 2006
    That's a bad combo.......you know, too much of a good thing.
  • amulford
    amulford Posts: 5,020
    edited May 2006
    What he said^^^
  • riglehart
    edited May 2006
    Glad I asked. I've heard enough. Thanks.
    Jolida Tube
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited May 2006
    Don't discount the Carvers with a regular pair of Polks, I've got a C-9 and a C-11 and IMO it can enhance the experience with M10 and M7's. Turn it off with my SRS 2.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2006
    It definetly "works" but I prefer a speaker to stand on it's own merits.
  • SRS_fan
    SRS_fan Posts: 11
    edited May 2006
    Nice piece of equipment but overkill.... with some music- it creates a interesting 'wow' factor but for the most part you will find it confuses the presentation and becomes mentally irritating. IMHO
    Partial Equipment List :
    Polk SDA-SRS
    KRELL HRC-2
    2 PERREAUX AMPS - 3150 Tops & 2150 Bottoms
    AudioPro B2-100 Subwoofer
    DBX 4BX
    Etc. Etc.
    On Wednesday the Polks will be replaced by the Martin Logan SUMMITS. It took a lot to put these old friends to the side.
    Respect....
  • BobMcG
    BobMcG Posts: 1,585
    edited May 2006
    To the best of my memory, I never knew them to be recommended by anyone or any company for use with SDAs.
  • jcaut
    jcaut Posts: 1,849
    edited May 2006
    I tried it after seeing this thread, just for kicks, and I DON'T recommend it. Granted, I didn't fiddle with speaker placement per the very detailed recommendations in the Carver manual. Perhaps if one disconnected the SDA cable... Anyway, I don't see how the two "effects" could be complimentary. I can't really describe what happened beyond saying that it was a big echoey--phasey, if you know what I mean-- mess.
    Of course, Sonic Holography can sound that way through "normal" speakers, if it's not set up properly, but not to the extent that I'm talking about.
    Jason
  • honestaquarian
    honestaquarian Posts: 3,260
    edited May 2006
    I currently have both.Although in two different rooms.I have tried using both in the past on the same system.NOT RECOMMENDED!Both the stereo dimensional array and the sonic hologram generator do the same thing.Which is interaural crosstalk distortion cancellation.Trust me taken together it is WAAYYYYY too much of a good thing.HATED IT!
  • 76911
    76911 Posts: 13
    edited June 2006
    I agree...I've used a Carver set up with my CRSs since the 80s and I only use the hologram function when I'm bored and for a short period of time...it is hard to improve on perfection.
  • dorokusai
    edited June 2006
    You and F1Nut should get along like kindred spirits.
  • djf
    djf Posts: 120
    edited June 2006
    I have a Hologram generator that I used to use back in the early 80's before I got the SRS's. Never bothered to hook it up since. I would recommend against it.
    Currently: A true classic, Back in N. Y. C., The Lamb Lies Down on Broadway
    Kinda sad. I hated NYC, but I sorta miss it...
  • honestaquarian
    edited June 2006
    The Newer Polk SDA's only run the crosstalk cancellation from 200HZ to 1000HZ.The carver's crosstalk cancellation runs full range like the older SDA's did.As a result i think the newer SDA's sound warmer and more natural than the hologram anyway.Like the older SDA's the hologram CAN at times sound a tad electronic and unnatural.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2006
    The globation of this fuzzification has digressed to the laughable.
    Yea, that tweeter fix had nothing to do with anything.
    RT1
