choosing surround speakers
michael marchet
I have Lsi 9 & LsiCB up front with Velodyne DLS375R sub
Driven by Yamaha 2600 what should I use for the rears Monitor Radius? Lsi 7s ? Mostly classical $ jazz some ht
Post edited by michael marchet on
Wrong forum, try the speaker forum
Good luck and welcome to the club.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Thank You>Skynut wrote:Wrong forum, try the speaker forum
I also have a Sunfire II, 9.1 , 7-200 watt receiver.
Rght now using:
1 pair RTI10 front main speakers>
CS2 center speaker (wilolo change to CS5
Planning on 2 pair of FX5 for surround & rear speakes
I also have a SAE202 Amplifier planning to use for 9.1Roy4828
Old Timer
Living room (20' x 12')
Sunfire Ultimate II , Receiver (7.1/9.1):
(200 watts RMS per channel at 8 ohms, or 400 at 4 ohms)
RTI-10 Front Speakers
CSI-5 speaker (Center Channel)
1 pair FXI-5 (Side suround) Dipole
1 pair FXI-5 (Rear speakers) Bipole
1 Infinity BU2 Subwoofer 12" 100 Wrms
Sony LCD 46" Flat Screen
Sony DVD/CD player
SAE A202 dual channel amplifier 200 watt RMS at 8 ohm or 400 watt at 4 ohms.
Monster HTS2600 MKII Power Conditioner
Fios Tv -
Thank You>
Rght now using:
CS2 center speaker (will change to CS5)
Sony DVD PLAYER
ONYKO dvd Player
2 other onyko reacivers (TX-SV636)
Sony Verga FD Trinotron 34" HD TCV
Infinity Bu-2 100 Watt Subwoofer
1 Pair Cerwin Vega VS120 sPEAKERS
1 PAIR iNFINITY Book shelf speakers (using as surround speakers (Tempory)
Roy4828
View Public Profile
Send a private message to Roy4828
Find More Posts by Roy4828
Add Roy4828 to Your Buddy ListRoy4828
Old Timer
Sony DVD/CD player
Fios Tv
