choosing surround speakers
michael marchet
michael marchet Posts: 1
edited May 2006 in Forum Testing Area
I have Lsi 9 & LsiCB up front with Velodyne DLS375R sub
Driven by Yamaha 2600 what should I use for the rears Monitor Radius? Lsi 7s ? Mostly classical $ jazz some ht
Post edited by michael marchet on
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    Wrong forum, try the speaker forum
    Good luck and welcome to the club.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Roy4828
    Roy4828 Posts: 6
    edited May 2006
    Thank You>
    I also have a Sunfire II, 9.1 , 7-200 watt receiver.
    Rght now using:
    1 pair RTI10 front main speakers>
    CS2 center speaker (wilolo change to CS5
    Planning on 2 pair of FX5 for surround & rear speakes
    I also have a SAE202 Amplifier planning to use for 9.1
    Roy4828
    Old Timer
    Living room (20' x 12')
    Sunfire Ultimate II , Receiver (7.1/9.1): :D
    (200 watts RMS per channel at 8 ohms, or 400 at 4 ohms)
    RTI-10 Front Speakers
    CSI-5 speaker (Center Channel)
    1 pair FXI-5 (Side suround) Dipole
    1 pair FXI-5 (Rear speakers) Bipole
    1 Infinity BU2 Subwoofer 12" 100 Wrms
    Sony LCD 46" Flat Screen
    Sony DVD/CD player
    SAE A202 dual channel amplifier 200 watt RMS at 8 ohm or 400 watt at 4 ohms.
    Monster HTS2600 MKII Power Conditioner
    Fios Tv
  • Roy4828
    Roy4828 Posts: 6
    edited May 2006
    Thank You>
    Rght now using:
    CS2 center speaker (will change to CS5)
    Sony DVD PLAYER
    ONYKO dvd Player
    2 other onyko reacivers (TX-SV636)
    Sony Verga FD Trinotron 34" HD TCV
    Infinity Bu-2 100 Watt Subwoofer
    1 Pair Cerwin Vega VS120 sPEAKERS
    1 PAIR iNFINITY Book shelf speakers (using as surround speakers (Tempory)
    Roy4828
    View Public Profile
    Send a private message to Roy4828
    Find More Posts by Roy4828
    Add Roy4828 to Your Buddy List
    Roy4828
    Old Timer
    Sony DVD/CD player
    Fios Tv
