up grades
MSALLA
MSALLA Posts: 1,602
edited May 2006 in Electronics
I was at the local Hi-Fi house yesterday looking for an amp.The salesmen said I might want to look at new speakers rather than an amp.
I am looking fo r more intensity out of my system. I currently have monitor 40, 30 & cs-1. Should I spend the money on new speakers or the amp. I like the sound from the moitors, They just don't put out that in your face sound.
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Post edited by MSALLA on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2006
    Describe "in your face". Are you looking for more overall volume, bass impact, piercing highs, cleaner vocals?
  • Airplay355
    Airplay355 Posts: 4,298
    edited May 2006
    What are you currently running your speakers with? The salesman might be right.
  • MSALLA
    MSALLA Posts: 1,602
    edited May 2006
    Bass impact more then volume. I am running the speakers off a Yamaha RX-V650. I went from boston vr towers to the monitor 40's due to room. I'm just not happy with the set-up.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • pearsall001
    pearsall001 Posts: 5,323
    edited May 2006
    What is your budget range for either a new amp or speakers?
  • Dennis Gardner
    edited May 2006
    Do you use a subwoofer?
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2006
    You should probably swallow a bunch of prescription drugs now, before it gets rough.
  • MSALLA
    MSALLA Posts: 1,602
    edited May 2006
    PSW 303. If I buy the drugs I won't have the cash for the staggering amount of money this is going to cost me.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • Airplay355
    edited May 2006
    If you want bass impact and you don't have any complaints about midrange or treble then **** getting an amp, go straight to a sub. Sell the sub you have and get something with more balls.
    You can build one, buy one, steal one...but I'd avoid polk subs. I love polk speakers, but I never really liked their subs much.
  • MSALLA
    MSALLA Posts: 1,602
    edited May 2006
    Ok, so it looks like speaker change. I looked at SVS subs and liked the cube style sub they had for around 400. As far as speakers go. I think that going from the Monitors to thr Rti would only be a slight increase insound quality.
    The Lsi's are 4ohm. I'm limited to bookshelf size but am looking for the sound close to what I got from the Bostons. What are my options?
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
