What do you guys think of this speaker wire.
P.HUNT
P.HUNT Posts: 211
I stumbled acrost this on the net check it out seems like a good price!
http://www.powerwerx.com/product.asp?ProdID=3355
PROCESSOR-- Sherbourn PT-7010A
AMP
Sherbourn 7/2100A
DVD
DENON 3910
BLU RAY
PS-3
PROJECTOR --- Panasonic ae-900u
SPEAKERS
Klipsch Ultra2 System
92" Screen
PS Audio power cords
Buttkickers
Post edited by P.HUNT on
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    If it is for the IB I don't think it will matter which kind you use as long as it is fat. IE 10g.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • P.HUNT
    P.HUNT Posts: 211
    edited May 2006
    I was even thinking about using it for all my speakers, and the IB
    AMP
    Sherbourn 7/2100A
    DVD
    DENON 3910
    BLU RAY
    PS-3
    SPEAKERS
    92" Screen
    Buttkickers
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    I run generic 10g to my rear speaks.
    When I decide to change out my front stage wires I will be making my own out of Silver plated OFC. Just to see if I hear a diference from my Monster z series.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • mantis
    mantis Posts: 17,561
    edited May 2006
    I don't think you need 10g wire. Unless your runs are stupid long, then I wouldn't use it. If they have 12 to 14 guage, I'd consider that.10g is a waste.
    Good price but it will be a **** to work with.
    Dan
    Dan
  • P.HUNT
    P.HUNT Posts: 211
    edited May 2006
    I will be running about 30 ft runs to my rear and side surrounds
    AMP
    Sherbourn 7/2100A
    DVD
    DENON 3910
    BLU RAY
    PS-3
    SPEAKERS
    92" Screen
    Buttkickers
  • ESavinon
    ESavinon Posts: 3,067
    edited May 2006
    The fatter the better. Great price.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • mantis
    edited May 2006
    See if that company offers 14-2. It's exactly what you need. As far as quality of that wire, I have no idea. Never used it
    Dan
    Dan
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2006
    You mean P H Phat.
    edited May 2006
    SKY-change the monster z's out.I used to run them on SRT's
    and felt they veiled the sound a bit.Changed to a silver cable
    and upgraded power cords and made a world of diff.
    Try it, you'll like it.:)
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    I think I am going to make my own silvers later but right now I am working on power protection.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited May 2006
    especially when it comes to terminating them. Posted this before, but these banana plugs can take a 10-gauge wire with minimal muss-n-fuss.
    http://www.speakerrepair.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=BS28&Category_Code=AHH_Banana
    $42 for a 28-pack, enough to terminate both ends of a 7.1 system (you are going to run a cable to the subwoofer).
    They're built like TANKS, easy to work with.
    Looks like a good deal on that wire, though. Shipping for me for a 100-foot roll was $15 (Midwest).
    If you get a spool, let us know how it turned out.
  • P.HUNT
    P.HUNT Posts: 211
    edited May 2006
    I ordered the big spool .
    I like those banana plugs I will be ordering a set of those to,thanks.
    AMP
    Sherbourn 7/2100A
    DVD
    DENON 3910
    BLU RAY
    PS-3
    SPEAKERS
    92" Screen
    Buttkickers
  • michael_w
    michael_w Posts: 2,813
    edited May 2006
    I have banana's similar to those, except they don't have the compression fit at the base of the plug, and are not too crazy about them. I absolutly hate that single flat head screw design. It's quite horrible at holding wire in there. I'd much rather have a simple compression fit than a single screw. It might not be an issue with the locking part of those gls audio plugs, but with mine they occasionally let go of the wire because I can't physically tighten the screw enough without damaging it.
  • mrbigbluelight
    edited May 2006
    my plugs just to see how much they could take.
    After a lot of beefcake, the head started to strip, the female threads in the plug itself never did. The tip of the screwdriver I was using wasn't perfectly flat and I'm sure that's what started the stripping action.
    With 10-gauge wire, tightening the bottom of the plug assures a darn tight fit, very secure.
    I like banana plugs because it makes swapping speakers very easy.
