Show me your ****(embly), and let me get in your guts baby!
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2006
    MW SWL9 Tube Pre- Amp
    mhardy6647 Posts: 33,042
    edited May 2006
    umm, I happen to have a somewhat fuzzy 'before' photo of the innards of my EICO HF-81 handy...
    (i.e., before the ceramic coupling caps and those other nasty, waxy caps were replaced).
    Don't have a rear-view of this particular amp, but I can provide a full frontal 'after' shot -- not the prettiest face, but a dang fine sounding amplifier nonetheless.
  • Mike682
    Mike682 Posts: 2,074
    edited May 2006
    Good idea!
    Here's some of my new Carver amp that I just bought from MSkeezer:
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    My **** is way dirtier than all yours. Maybe I'll remember next time I rearange my system.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • jtgranby
    jtgranby Posts: 887
    edited May 2006
  • jtgranby
    jtgranby Posts: 887
    edited May 2006
    The pic of the guts.
    JT
  • dorokusai
    edited May 2006
    Jaguar Blue Chassis
    Beardog03 has a Cary Integrated Amplifier with a Jaguar Green chassis...do a search if you're interested in pictures.
    Everyone - Great pics! Keep 'em coming...show me more Audio T&A :D
  • Polkitup2
    Polkitup2 Posts: 1,619
    edited May 2006
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2006
    Since I just moved my Parasound in for preamp duty and moved out my Yamaha to another system, I thought I'd open her up and clean her out. Snapped some pictures while I was in there. No front fascia or rear end pics, though.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • dorokusai
    edited May 2006
    Thanks AGAIN, to those folks willing to spin a tip. If you don't "pop the top" on your gear, you might want to look into another hobby.
    I live for this, and everything gets an eyeball...if it's a really cool piece, I take some pics. Unless there is a sticker stating "Warranty Void" or some shite, break it open and take a look.
    You should be involved in what you own, plain and simple. If you don't, you're lame.
  • Mike682
    edited May 2006
    I agree 100%. When I first look at gear, I always take a peek through the grills. After I purchase, I'll set it up, listen for a few, then off comes the top.
    Look for pics of my HK AVR soon...
    Mains: polk R30
    Center: polk CSi3
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2006
    Doro, Question about your Cary SPL-98 pre amp. First how do you like it? Second what is the chip with a crystal a remote pickup / controller? I consider buying a SPL-98 Pre amp myself one day ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    SCompRacer Posts: 8,352
    edited May 2006
    BAT VK-3i.
    edited May 2006
    Pacific Valve & Electric Company L's Audio A28. They used to sell these as components/kits but those pages are gone now. Not a bad starter tube pre amp. With remote.
    This belongs to Normanality and he let me use it when I was between pre amps.
  • audiobliss
    edited May 2006
    That does look like a nice lil' tube pre...with a remote.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Normanality
    Normanality Posts: 297
    edited May 2006
    Here's another nice little basic tube linestage. No remote though.
    Audcom AP100
  • Normanality
    edited May 2006
    The innards of an Innersound 300 WPC active crossover bass amp.
    Nice design, well constructed.
  • audiobliss
    edited May 2006
    While I had my IC's off, trying to put them on correctly, I figured I might as well open everything up for a quick look.
    The case came off the Parasound P/HP-850 very easily with only 6 screws...especially since they were really loose...ohskigod, you leave all your screws that loose? :p
    Sorry for the poor front and rear pics.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited May 2006
    Here are some pics of my Rotel RCD-02. The case on this was quite a bit more finicky, as you had to slide it off toward the back, and it fit kinda tight. Not difficult, though...just more difficult than the Parasound.
    Again, sorry for the poor front and rear shots. And least the shots of the guts came out a lot better.
    The little chip that says 'Sony CXP82440A'...what's that for? Is that to control the CD drive, which I assume is Sony? I couldn't find anything on it that I thougth looked like a DAC.
    I guess it was made in 2002, eh?
    I wonder whose logo that little squigly line is. It's on the main board and the one the analog RCA output jacks are on.
    Four guys tested it out/looked over it, huh?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Normanality
    edited May 2006
    Here's a single shot of my VTL 2.5 preamp.
    I was a little disappointed in how little is actually inside!
    I replaced the original tubes with Mullard CV4003 and Sylvania 6350's.
    Very nice detailed sound.
  • disneyjoe7
    edited May 2006
    Looking at some spec's myself it's a Sony Microcontroller // but looks like it could be driving the display perhaps checking on front panel switches being push or not.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • audiobliss
    edited May 2006
    Sounds perfectly plausible to me.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • faster100
    faster100 Posts: 6,124
    edited May 2006
    Myth busted? :D plausable ?
    I need to take some shots of my pas 3 guts.. way to typical though i guess
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    edited May 2006
    Old gear....Adcom GFA-555
    edited May 2006
    Adcom GFA-5400.
  • WilliamM2
    WilliamM2 Posts: 4,713
    edited May 2006
    Denon POA-2400 power amp:
    1.jpg 297.4K
    2.jpg 445K
    3.jpg 458.4K
    4.jpg 321.4K
    5.jpg 481.9K
  • WilliamM2
    edited May 2006
    Rotel RB-951 MkII power amp:
    6.jpg 254.4K
    7.jpg 506.6K
    8.jpg 367.1K
    9.jpg 221.1K
  • dorokusai
    edited May 2006
    Nice.
  • dorokusai
    edited June 2006
    I've owned a bunch of Rotel vintage gear and it's cool, but I haven't bought many pieces since owning them originally. The new gear really threw me for a loop, as I really liked the aesthetics and the simplicity of the interface. This is in regards to the RSP-1066...and it's siblings.
    They're internally conservative but externally impressive. There is nothing internal that isn't done in the same price bracket but it's miles above generic gear in regards to layout and build quality.
    Blah, blah...here's some guts and ****!
  • del44
    del44 Posts: 686
    edited June 2006
    Shanling integrated. Got it off audiogon. Pretty clean.
