My latest DIY speakers
WardswebWardsweb Posts: 876
edited December 2009 in DIY, Mods & Tweaks
These only need veneer to be complete but I've got a Lone Star Bottleheads meet at my place on May 20th, so they will play as is. After the meet I'll take the drivers out and veneer.
Drivers: Altec 416-8C LF, Altec 802-8G on 511B horns HF and JBL 077 UHF. The crossover is a combination of an Altec N501 and JBL 3106.
Living room: Clearaudio Champion II turntable, EAR 834P phono pre, Auralic Altair DAC/server, PS Audio Quintessence power, DIY 6H30 Class A Linestage, ASL AQ1006 845 DT MKII mono block amplifers, DIY Altec/JBL speakers, DIY Baltic birch rack
Sun room: DIY Nelson Pass B1 w/Korg NuTube pre, Technics SL-1700 turntable, DIY Anaview d-class mono block amplfiers, JBL C50 Olympus speakers with custom Smith horns, Mapleshade Samson rack
Den: Onkyo TX-NR929 receiver, Oppo BDP-103 player, Behringer EP 4000 sub amp, Electrovoice DX-38 active, DIY EL-34 horn amp, Behringer NU6000 bass amp, Klipsch Jubilee speakers, Martin Logan Cinema center, JBL SAT2 surrounds, Danley DTS-10 sub
Dining room: Pro-Ject RPM 1 turntable, Shanling CD-T1500 SACD, Sumo Athena pre, SST Ampzilla 2000 amps, Quad 2905 speakers
Post edited by Wardsweb on
«13
  • WardswebWardsweb Posts: 876
    edited May 2006
    This shows the skeleton structure. A combination of CNC baltic birch and MDF.
    edited May 2006
    The sides are done in 4 layers of kerf MDF. These have been filled with bead blasting media (finer than sand), interior of the cabinet is sprayed with a non-harndening soundproofing and fiberglass lined.
  • RuSsMaNRuSsMaN Posts: 17,995
    edited May 2006
    Incredible work, as always. I SOOOO wish I had woodworking skills.
    Those would probably sound great on my 211 SET's (for sale) ;).
  • dorokusaidorokusai Posts: 25,489
    edited May 2006
    That sets the bar for DIY in this place....holy cow.
    edited May 2006
    Think you'll make it down for this saturday's shindig? No obligation to, just wondering.
    edited May 2006
    It's still up in the air, I want to, just depends on what I get done this week.
  • Paul in CanadaPaul in Canada Posts: 178
    edited May 2006
    Wow! Great job. One of these days I would like to try build some speakers. If you don't mind me asking about how much time and money would go into a project like this?
    Polk RTi 8's
    Polk CSi 5
    FXIA4"s
    Outlaw Audio M200 x2
    Denon AVR 2805
    Sony CDP C345
    Paradigm PW2200 Sub
    Panasonic 50"
    "It's futile to have a battle of wits with an unarmed person." demaples July 29/08
    edited May 2006
    My 2-way rosewood corner horns took about a year, part time and came in around $1500. The main cost is for the drivers, as is the case with my present 3-way speakers. The total will come in just under $2K with $1300 of that being the drivers and crossovers. Now if you had to buy these speakers you would be spending somewhere in the neighborhood of $6k-7K pretty easy. With better drivers these would run more like $10K.
  • unc2701unc2701 Posts: 3,587
    edited May 2006
    *Smacks forehead* I don't know why I never thought of layering kerfed wood. I've always been hesitant to use kerfing on speakers (cuts would be huge for proper cabinet thickness) but layers would fix that. DOH!
    Very nice work... would love to get my hands on a CNC. My unkle makes furniture, but part of his whole sales pitch is the uniqueness of each of his pieces- so there no chance of a CNC there. He is good for a 3 hour speech on joinery, though.
    Backburner:Krell KAV-300i
  • hoosier21hoosier21 Posts: 4,406
    edited May 2006
    It would be unreal to have access to a CNC
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    edited May 2006
    When layering, place the kerf cut facing each other. Then fill with whatever you want.
    edited May 2006
    Check you local yellow pages for wood shops, furniture/cabinet makers and lumber yards. You can pay someone to do the CNC for you.
  • steveinazsteveinaz Posts: 19,494
    edited May 2006
    Outstanding job, I bet those babies rock!
    Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amplifier: Parasound Halo A21 - Speakers: PSB Imagine T2 - Cables: Kimber Hero XLR; Kimber 8VS Bi-Wire; DH Labs D-75 dig coaxial
    edited May 2006
    If it isn't in Russ's garage now....that's not likely to happen.
  • amulfordamulford Posts: 5,198
    edited May 2006
    Very nice work, Luther. If you could, I'd love to see how the veneer turns out.
    How efficient are they? Did you have any trouble integrating the two crossovers?
    I smell ****, burning ****, glowing cherry red spanked ****.
    RT1
  • MazerothMazeroth Posts: 1,585
    edited May 2006
    Freakin' beautiful!
    DiY speaker builders...UNITE! :D
    edited May 2006
    The speakers are around 100dB efficient, maybe a little more. So a few watts from a 2A3 amp work fine but 50 from a EL34 push pull can rock the house.
    The crossover worked well by just adding the UHF section of the JBL 3106 to the Altec N501. Both the HF and UHF have variable attenuation, so it can be dialed in to taste.
  • MoreantsMoreants Posts: 70
    edited May 2006
    Very impressive! Beautiful work and sound to match I would guess.
    Suddenly I feel like Fred Flintstone.
    I remember when 'broadband' meant The Go-Go's.
  • tonybtonyb Posts: 32,506
    edited May 2006
    Very nice job,we are all envious of your skills.
    Anytime you want to build me some.......
    Sure you hear that from 100 people a day!
    Beautiful job!!!
    edited May 2006
    Bass ports done, just need to install the crossovers inside and veneer, but listening is warming my soul. Audio meet this weekend will be proud papa syndrome.
  • ApexApex Posts: 69
    edited June 2006
    Absolutely gorgeous..
    H/K AVR7000
    "LSI25's bi-wired with 2.4s
    Mirage OM c2 Center "LSiC soon"
    FX300i rears "LSi15's soon for the rears".
  • Early B.Early B. Posts: 8,171
    edited June 2006
    Ward -- you gotta give us an update on this project...
    "God grooves with tubes."
  • ND13ND13 Posts: 7,648
    edited June 2006
    Wood!!!
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • george danielgeorge daniel Posts: 12,087
    edited June 2006
    Class act :)
  • disneyjoe7disneyjoe7 Posts: 11,520
    edited June 2006
    Very Nice indeed.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • faster100faster100 Posts: 6,247
    edited June 2006
    That whole rig is unreal.. Nice
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    edited November 2009
    Over three years in the making, but I finally veneered my horns and my 2-channel rig has had a few changes. So, here it is in all it's glory.
  • kawizx9rkawizx9r Posts: 5,179
    Wow...Im jealous ;)
    Congratulations on the speakers, they're beautiful and I can only imagine that they sound even better!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    LUTHER!
    I guess I need to revive my membership on that other board. Let's get the LSB's going again, if you haven't already, I miss you and Fred and all those other lunatics.
  • hearingimparedhearingimpared Banned Posts: 21,473
    Absolutely beautiful!!! The whole rig.
Howdy, Stranger!
