hooking up lsi25
pilotab
pilotab Posts: 2
I recently got the lsi25s and the denon avr4306. What I need to know is how to hook them up and specifically can the builtin sub be wired like a seperate sub? thanks and sorry for the newbie question
Post edited by pilotab on
    F1nut Posts: 52,243
    edited May 2006
    Owner's manual?
  • dorokusai
    dorokusai Posts: 25,625
    edited May 2006
    Just wire them up like normal speakers to the L&R speaker outputs from the Denon. Yes, you also have the option of a LFE Input(Subwoofer Line Level) on the LSi25, for a seperate subwoofer connection using the L&R pre-outs from the Denon.
    In addition, you have the option of bi-wiring/bi-amping them, but consult your owners manual for more information about these methods.
    I would keep it simple for now, get adventurous later.
  • pilotab
    pilotab Posts: 2
    edited May 2006
    dorokusai wrote:
    Just wire them up like normal speakers to the L&R speaker outputs from the Denon. Yes, you also have the option of a LFE Input(Subwoofer Line Level) on the LSi25 for a seperate subwoofer connection using the L&R pre-outs from the Denon.
    Thanks for the advice. I also had a questions about amps. I was scanning some other threads and people were saying that its a good idea to get a multi channel amp to pwr these speakers. Can you explain and suggest an amp or better yet a receiver that can pwr these speaker effectively?
    edited May 2006
    Key word here is " effectively ".IMHO...no receiver can do it.
    KNOW what you need before buying speakers of higher quality.
    Get an amp,plenty good one's to be had used on ebay or
    audiogon from the likes of B&K,Adcom,Rotel,Parasound.
    edited May 2006
    F1nut wrote:
    Owner's manual?
    'nuff said.
  • dorokusai
    edited May 2006
    There are definetly AVR's that can do it, but we're not talking cheap gear at this point...and I'm not getting into it due to a lack of interest. I try not to recommend gear anymore.
    Do a search on the board, there is a wealth of information about this subject...there are some horrible suggestions and advice but moreso excellent suggestions with great first person experiences.
    Search on "LSi...power...amplifier...seperates...receiver" with those keywords, in varying order, and should get you quite a bit of reading material.
  • SuperDave
    SuperDave Posts: 168
    edited May 2006
    Hook it up and see how you like it....all the while keeping your eyes(and ears) open for a separate amp to add later for added ooomph. You won't be sorry, and you will see what a difference it makes.
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Sony XBR 27"
    BrightHouse DVR
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
    SuperDave
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2006
    Just make sure you don't blast it too loud, or you might find those expensive speakers need new tweeters before you even got them broken in!:eek:
